17255 Discussions
Problem installing Quartus II 9.0 on Ubuntu
Hi everyone,
I'm having a problem here trying to install Quartus in my Ubuntu.
I did change sh default to bash and install tcsh package successfuly, but i still get the same message:
install: not recognized option '--auto'
Try `install --help' for more information.
With GUI setup i got the same issue.
Actualy i did setup it in my notebook once, but now i can't. Maybe an ubuntu update is blocking my system to setup. I realy don't know.
Any help?
the problem may be with linux search path.
since Linux will look first at the $PATH variable and not the current directory.
so it might try to run install script some where else.
to resolve this add :
./install
this should run the install script on the directory your pwd shows.
Avi.
Did you run on x386 or x64?
If the later, did you install ia32-libs?
