17253 Discussions
Problem involving parameters, real type, functions, and port declarations
This one is difficult to explain, so I wrote/tested several examples. These examples are contrived, but they show the problem specifically.
Quartus allows me to resize inputs according to functions performed on parameters, like this:
//This module works fine in ModelSim and Quartus. //It uses a function on the parameter value to set the number of input bits module param_function_test1# ( parameter num_bits=3 ) ( input in_bits, output out_bit ); //Logic just so the module isn't empty... assign out_bit = |in_bits; function integer get_msb( input integer x ); return x-1; endfunction endmodule Okay, now I want a module that sizes a port based on a different function that happens to take a real type.
//This module works fine in ModelSim, but Quartus throws a fit about "some_val" not being constant and real data types not being //supported module param_function_test2# ( parameter some_val=3.5 ) ( input in_bits, output out_bit ); //Logic just so the module isn't empty... assign out_bit = |in_bits; function integer ceil( input real x ); return ((x - integer'(x)) > 0) ? integer'(x) + 1 : integer'(x); endfunction endmodule
Crash and burn. At first I thought maybe Quartus just does not support the real type at all, but then I noticed the "Quartus II Support for SystemVerilog" site lists real and shortreal as:
"Supported for parameters." I am only using the real type for a parameter in that block of code, but it appears unsupported.
For a reference, I made a module that uses a real parameter and does the same function math without the function call:
//This module works fine in ModelSim and Quartus, implying that Quartus knows how to handle reals in parameters just fine. module param_function_test3# ( parameter x = 3.5, ceil = ((x - integer'(x)) > 0) ? integer'(x) + 1 : integer'(x) ) ( input in_bits, output out_bit ); //Logic just so the module isn't empty... assign out_bit = |in_bits; endmodule That module works as I would hope: Quartus recognizes ceil(3.5) as 4 and gives me a 5-bit input vector.
This is frustrating because I often size vectors according to operations on parameters. This means all such math that includes reals has to be done in the module header, which is unfortunate for two reasons:
1) If different modules need the same math, it has to be manually copied and pasted into each module header. I can't package it as a function.
2) Module headers get more cluttered and confusing
Will Quartus support constant functions on reals in the future?
I don't know Verilog but I know that in VHDL when you declare a function in an architecture, its scope is only within the architecture itself and can't be used for things outside it, such as port sizes. The only way to do something like that is to define the function outside, on a more global level, for example in a library package. Maybe there is a similar solution in Verilog.
I would like to put the function into a package, and the SystemVerilog language allows that. The problem is specifically with Quartus. It is not allowing functions that take the "real" type as an input. It allows functions in port declarations (as shown in the first code example). It also recognizes reals (as shown in the third code example), but it will not let me put reals through a function (as shown in the second example). It seems to be an arbitrary limitation. ModelSim has no problem running the same code that Quartus won't build, even though everything I'm doing is synthesizable (since the function is called before synthesis).
