17258 Discussions
Problem: "Error: Can't write to Atom Netlist File "
Hi all,
i'm a newer on this forum; i've got a problem after compiling a vhdl project with Quartus II v8.1.
After starting compilation, it appears this errors:
error: can't write to atom netlist file
error: can't write to file
Where is the problem? What have I to do to solve it?
Thanks a lot for your help.
i would think the atom netlists are written to the db or incremental_db directories within your project directory. try deleting them and compiling again
if that doesn't work try creating a simple project from scratch and compiling
