17259 Discussions
Problem simulating Nios II design and external logic
I have a project based on a Nios II processor and external logic connected to it via avalon interface. I know how to simulate a Nios II design, and how to simulate classical VHDL design, but I have problem to simulate a mixed one.
I tried by launching ModelSim from Nios IDE (Run as -> Nios II ModelSim), but ModelSim does not have the vhd file of external logic, and if I add it all its input/output signals stay 'U'.
I also tried by following the steps in Quartus Handbook 3, Perform Simulation Using the ModelSim-Altera Software chapter, giving all the vhd files to ModelSim but when I run the simulation, I have the following error :
"# Fatal error in Process memory at C:/altera/90/modelsim_ase/win32aloem/../altera/vhdl/src/altera_mf/altera_mf.vhd line 38968"
Thanks in advance
Jérôme
Look in the vhdl file with the same name as the .sopc file you generated in SOPC builder. At the bottom of the file is places you could add your own logic to the simulation.
Indeed we find the test bench of the system at the end of the file. So I add my component with "component" and then "port map", but I have the following warning in ModelSim, and indeed, the component does not appear in the instances :
"Warning: (vsim-3473) Component instance "cut : testcomponent" is not bound."
I think it is because it does not know where find the vhdl file corresponding to my component, but I don't know how to do it.
entity test_bench is end entity test_bench; architecture europa of test_bench is component processor is port ( -- 1) global signals: signal clk : IN STD_LOGIC; signal reset_n : IN STD_LOGIC; -- the_led_pio signal out_port_from_the_led_pio : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); -- the_test_component_conduit signal coe_avs_address_from_the_test_component_conduit : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); signal coe_avs_chipselect_from_the_test_component_conduit : OUT STD_LOGIC; signal coe_avs_read_from_the_test_component_conduit : OUT STD_LOGIC; signal coe_avs_readdata_to_the_test_component_conduit : IN STD_LOGIC_VECTOR (31 DOWNTO 0); signal coe_avs_write_from_the_test_component_conduit : OUT STD_LOGIC; signal coe_avs_writedata_from_the_test_component_conduit : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); signal coe_csi_clk_from_the_test_component_conduit : OUT STD_LOGIC; signal coe_csi_reset_from_the_test_component_conduit : OUT STD_LOGIC ); end component processor; signal clk : STD_LOGIC; signal coe_avs_address_from_the_test_component_conduit : STD_LOGIC_VECTOR (7 DOWNTO 0); signal coe_avs_chipselect_from_the_test_component_conduit : STD_LOGIC; signal coe_avs_read_from_the_test_component_conduit : STD_LOGIC; signal coe_avs_readdata_to_the_test_component_conduit : STD_LOGIC_VECTOR (31 DOWNTO 0); signal coe_avs_write_from_the_test_component_conduit : STD_LOGIC; signal coe_avs_writedata_from_the_test_component_conduit : STD_LOGIC_VECTOR (31 DOWNTO 0); signal coe_csi_clk_from_the_test_component_conduit : STD_LOGIC; signal coe_csi_reset_from_the_test_component_conduit : STD_LOGIC; signal cpu_data_master_irq : STD_LOGIC_VECTOR (31 DOWNTO 0); signal out_port_from_the_led_pio : STD_LOGIC_VECTOR (7 DOWNTO 0); signal reset_n : STD_LOGIC; -- <ALTERA_NOTE> CODE INSERTED BETWEEN HERE --add your component and signal declaration here component TestComponent is port(csi_clk : IN STD_LOGIC; csi_reset : IN STD_LOGIC; avs_chipselect : IN STD_LOGIC; avs_write : IN STD_LOGIC; avs_read : IN STD_LOGIC; avs_address : IN STD_LOGIC_VECTOR(7 DOWNTO 0); avs_writedata : IN STD_LOGIC_VECTOR(31 DOWNTO 0); avs_readdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0) ); end component; -- AND HERE WILL BE PRESERVED </ALTERA_NOTE> begin --Set us up the Dut DUT : processor port map( coe_avs_address_from_the_test_component_conduit => coe_avs_address_from_the_test_component_conduit, coe_avs_chipselect_from_the_test_component_conduit => coe_avs_chipselect_from_the_test_component_conduit, coe_avs_read_from_the_test_component_conduit => coe_avs_read_from_the_test_component_conduit, coe_avs_write_from_the_test_component_conduit => coe_avs_write_from_the_test_component_conduit, coe_avs_writedata_from_the_test_component_conduit => coe_avs_writedata_from_the_test_component_conduit, coe_csi_clk_from_the_test_component_conduit => coe_csi_clk_from_the_test_component_conduit, coe_csi_reset_from_the_test_component_conduit => coe_csi_reset_from_the_test_component_conduit, out_port_from_the_led_pio => out_port_from_the_led_pio, clk => clk, coe_avs_readdata_to_the_test_component_conduit => coe_avs_readdata_to_the_test_component_conduit, reset_n => reset_n ); process begin clk <= '0'; loop wait for 10 ns; clk <= not clk; end loop; end process; PROCESS BEGIN reset_n <= '0'; wait for 200 ns; reset_n <= '1'; WAIT; END PROCESS; -- <ALTERA_NOTE> CODE INSERTED BETWEEN HERE --add additional architecture here CUT : TestComponent port map(csi_clk => coe_csi_clk_from_the_test_component_conduit, csi_reset => coe_csi_reset_from_the_test_component_conduit, avs_chipselect => coe_avs_chipselect_from_the_test_component_conduit, avs_write => coe_avs_write_from_the_test_component_conduit, avs_read => coe_avs_read_from_the_test_component_conduit, avs_address => coe_avs_address_from_the_test_component_conduit, avs_writedata => coe_avs_writedata_from_the_test_component_conduit, avs_readdata => coe_avs_readdata_to_the_test_component_conduit); -- AND HERE WILL BE PRESERVED </ALTERA_NOTE> end europa; --synthesis translate_on
Have you added the file containing your test component to the modelsim project, and compiled it? If not that may be the problem.
I have done simulation of my own components added to a Niso II simulation, and i allways had to add the files containing my own components to the modelsim project manually.
Yes, that was the problem. We have to add the vhdl file to the ModelSim project and compile it before. Thanks for your help.
