17267 Discussions
Problem using SOPC builder ...
Hello all!
I am trying to open a predefined project (de2_net.qpf). when opening the SOPC builder, it gives an error "Warning: isp1362_0: Used isp1362 1.0instead of 1.0.1)"
I am using 9.0 version..
can any1 tell me how to get rid of it .. I m new to this system
Thank you !
This message means, that the initial version for the ip module isp1362 was 1.0 but you open it with 1.0.1
quartus / sopc stores the information of the installed sopc ip modules in a file (no idea right now which one it is)
if you open sopc, get this message, and the save the sopc projects, mostly these messages are gone as you now have stored it with the current version. but sometimes this message stays.
sometimes it helps to open this custom ip and resave it. this helps when more than one pc is working with the sopc ip modules. cause now it updates the sopc ip cache information
