Problem with LPM_MUX
This is a basic problem but it is catching me out, I am trying to implement a simple 2-to-1 mux using the LPM but Quartus is kindly telling me I am using the 2D_std_logic type incorrectly
mux : LPM_MUX GENERIC MAP( LPM_WIDTH => 12, LPM_SIZE => 2, LPM_WIDTHS => 1 ) PORT MAP ( DATA(0, 11 downto 0) => Ramp_Up_I(11 downto 0), DATA(1, 11 downto 0) => Ramp_Down_Q(11 downto 0), SEL => clockdivide(0), RESULT(11 downto 0) => Muxed_IQ(11 downto 0) );The error is
slice of object cannot be specified for object that has an array type of more than one dimension
Any help would be greatly appreciated
there is no such thing as a 2D_std_logic type. You also cannot index DATA like you have (it is illegal VHDL)
Did you generate the mux via the megawizard? or are you trying to do it manually?
Hi Tricky, thanks for replying. I am trying to implement it manually. The std_logic_2d type is used by Altera in the LPM component declaration, this is taken directly from Altera
component LPM_MUX
generic (LPM_WIDTH : natural; -- MUST be greater than 0 LPM_SIZE : natural; -- MUST be greater than 0 LPM_WIDTHS : natural; -- MUST be greater than 0 LPM_PIPELINE : natural := 0; LPM_TYPE : string := L_MUX; LPM_HINT : string := "UNUSED"); port ( DATA : in std_logic_2D(LPM_SIZE-1 downto 0, LPM_WIDTH-1 downto 0); ACLR : in std_logic := '0'; CLOCK : in std_logic := '0'; CLKEN : in std_logic := '1'; SEL : in std_logic_vector(LPM_WIDTHS-1 downto 0); RESULT : out std_logic_vector(LPM_WIDTH-1 downto 0)); end component;
I hate it when altera do odd things with std_logics
basically, std_logic_2D is nothing to do with std_logic_vector, so you cannot assign std_logic_vectors directly to std_logic_2D types, other than doing it bit by bit. You have create a local std_logic_2D type signal and assign stuff into that.
But what makes it more annoying is that you cannot use (N downto M) or (N to M) in 2D arrays. You can only access individual elements (in this case bits), or assign the entire thing.
Now if only they'd made an array of std_logic_vectors, instead of a 2D array of std_logic, then everything would be fine!
My advice - Dont use the LPM library for simple things - just imply it in the code:
signal a, b : std_logic_vector(11 downto 0); .... --for an uclocked mux: result <= a when sel = '0' else b; --for a clocked mux process(clk, reset) begin if reset = '1' then result <= (others => '0'); elsif rising_edge(clk) then if sel = '0' then result <= a; else result <= b; end if; end if; end process;
