17267 Discussions
Problem with Qsys when creating PIO
I am beginning to create a hardware with Qsys.
The system that I want to create has 4 ports: clk(input), reset(input), a1(input), a2(output).
I added a nios processor, a on-chip memory, a jtag uart, a pio_0, a pio_1.
I also followed step by step as the instruction of creating the simplest nios program said.
I set pio_0 to be input, pio_1 to be output in Basic Settings/Direction.
However, when I generate this hardware, it only has 2 ports: clk and reset.
I saw that 2 PIO components have external_connect but I don't know where to connect them.
Would you please tell me why I can't create 4 ports?
I'm sorry. I solved it.
--- Quote Start ---
--- Quote End ---
Hey mate
How did you solve it ?
thnx
Double click the 'external connection' and you should get a name you can edit. Put a suitable name here, then generate, and you will have the relevant signals as ports on the QSYS system.
