17268 Discussions
Problem with a design suitable for Altera and Xilinx
I have a design that can be used for an Arria2 or for a Xilinx FPGA.
On schematics I have a generic that choose what to generate but I'm having a little big problem.
The head of the file, generated by HDL Designer, do something like:
LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; LIBRARY UNISIM; USE UNISIM.VCOMPONENTS.all; USE UNISIM.VPKG.all; LIBRARY altera_mf; USE altera_mf.all; LIBRARY Lib_Fifo_Altera; LIBRARY Lib_Geral;The bold lines just give me the following error:
Error (10481): VHDL Use Clause error at fifo_16x69_fwft_ws_gen_sc_struct.vhd(55): design library "UNISIM" does not contain primary unit "VCOMPONENTS"I have something like 50 structs and it's a mess hand editing one be one, just to comment that lines and have to do it again if I generate the struct. :cry:
How can I put Quartus ignoring that Lib's?
Thanks for the help
Maybe just create 'empty' packages or just containing one constant you can use in assertions in other design files.
