17254 Discussions
Problem with new OpenCL installation (no device found)
Hi everyone.
This is not the first time install all the files to develop OpenCL programs for Altera FPGA.
Last time it was Windows 7 and it was working fine. This time it's windows 10 and when I run my application it tells me no Altera device library founds hence no device is found.
But the command "aocl diagnose" says everything is fine. I can flash kernels as well. I don't get where is the problem. I have installed everything the same as on the other pc.
Online there is no info about this warning. Does anyone know what is causing this problem?
Ok solved. Apparently you need to check your Visual Studio installation. I have updated it and installed some more features missing. This thread can be closed. Thanks
