17264 Discussions
Problem with programming in AS mode with Quartus rogrammer
Hi there, the problem is that the output .pof file from compilation is not correct, the message is:
Error: Can't recognize silicon ID for device 1
I checked the default program of DE1 board and found out that the device for active serial programming is "EPCS4", while the compilation .pof file is "EPCS16". How can i fix that?
Kevin
PS: There is no problem with JTAG, the device in project properties is "EP2C20F484C7"
From Quartus:
1 - Assignmentj->Settings->Device
2 - Click the "Device and Pin Options" button.
3 - Click on the "Configuration" tab.
4 - Make sure the "Use Configuration Device" dropdown box is set to EPCS4.
Jake
Thanks, problem solved by recompiling with new settings.
Kevin
