I am having an issue when trying to update the symbol block. The text boxes that are generated on the right of the block are all too small for the text. This happens in both version 13.0.1 and version 11. It didn't happen on the PC that I used to work on (both PCs are running Windows 7 64-bit). Please see an example of the problem below:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8547 It's really frustrating. I have tried adjusting the text box sizes, even if this works, it's very tedious to do this for every update and every text box. I have tried to adjust the Quartus settings on the two PCs to be identical but nothing seems to correct the error. I am thinking that it must be a problem with OS settings. Does anyone have any suggestions?- Tags:
- FPGA Design Tools
