17252 Discussions
Problems with OpenCL SDK 13.0 on Windows 7
hai all.
i installed Quartus II 32-bit Shell and Altera SDK for OpenCL
C:\Users\Udaya>quartus_sh --version
Version 13.0.0 Build 156 04/24/2013 SJ Full Version
Copyright (C) 1991-2013 Altera Corporation
C:\Users\Udaya>aoc --version
Altera SDK for OpenCL, 64-Bit Offline Compiler
Version 13.0 Build 190
Copyright (C) 2013 Altera Corporation
C:\Users\Udaya
after installing i cannot find opencl.exe plz someone help me with this issue
There is no opencl.exe The two programs you use are 'aoc' which is the compiler and 'aocl' which is the OpenCL toolkit. You can find the documentation that explains this in more detail here: http://www.altera.com/literature/lit-opencl-sdk.jsp
Also note when you use OpenCL, the 64-bit version of Quartus will be used as well as 64-bit libraries for the host application.
