17254 Diskussionen
Process Statement must contain only one Wait Statement : More WAIT
Geehrter Beitragender II
4.550Aufrufe
I try to use a code but there are more WAIT. How can i change it ???? I change "wait until" to wait until Clk'event ????
StartTx <= '0'; DataToTx_M <= "0101010101010101"; DataToTx_S <= "1010101010101010"; --wait until Clk = '1'; wait until Clk'event and Clk='1'; reset <= '0'; --wait until Clk = '1'; wait until Clk'event and Clk='1'; StartTx <= '1'; wait until Clk = '1'; StartTx <= '0';
The error is Error (10398): VHDL Process Statement error at simpleSPI_M_S_tb.vhd(100): Process Statement must contain only one Wait Statement
Thanks for your help
Jennifer
5 Antworten
3.372Aufrufe
The rule is correct - you can only have 1 wait statement in a process if you want to compile the code for an fpga.
Your code looks like software, not hardware. I highly recommend you find a VHDL tutorial or VHDL textbook that has digital logic examples.
VHDL is a hardware description language, not a programming language. Have you drawn your circuit on paper (or visio or something) before you tried to write the code? as a description language, you need to know what you are describing first.
3.372Aufrufe
--- Quote Start ---
--- Quote End ---
Thanks BUT it is a sample that find on web !!!!! How can i change this code ???
Best regards
Jennifer
3.372Aufrufe
THis code sample you have found is probably from a testbench, where many wait statements are allowed and often required.
3.372Aufrufe
--- Quote Start ---
--- Quote End ---
Yes you are right, the name is "tb"
I look for a SPI Master programme.
Jennifer
3.372Aufrufe
When writing code for an FPGA it's best to avoid using wait, it will make code more difficult to read, and too tempting to put several of them, making it impossible for the software to synthesize. It's better to stick with the recommended template for a clocked process:<optional_label>: process(reset, clk) is -- Declaration(s) begin if(reset = '1') then -- Asynchronous Sequential Statement(s) elsif(rising_edge(clk)) then -- Synchronous Sequential Statement(s) end if; end process;
Codes for test benches usually can't directly be adapted for synthesis, you have to rethink the design. I recommend to use a state machine that can generate a reset pulse if needed, then wait for some data to transmit and send it on the SPI bus. You'll also need a bit counter and a shift register.
Antworten
