17263 Discussions
Pushbutton reset creating problem
I am facing problem with pushbutton reset in stratix board. Sometimes the button works well n sometime it didnot.
Is it possible to give reset from some other source( pushbutton/ Dip)?
Thanks in advance
Usually each development board has a dedicated reset pin which is the master reset signal for the FPGA design loaded, and connects to the special function pin called DEV_CLR on the FPGA.
Find out the proper pin on your Stratix board
