QUESTA - .do file
Useral98
How can I generate the .do file in questa?
I know that later when that file is generated you have to add or delete lines of text. What lines should I add or delete and how do I generate the .do file?
RichardTanSY_Altera
You create a blank .txt file and change the file extension from .txt to .do file.
You may checkout the user guide below for Questa simulation Quick-Start :
Quartus Standard Simulation Flow: https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
Quartus Pro Simulation Flow: https://www.intel.com/content/www/us/en/docs/programmable/691278/21-3/quick-start.html
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
RichardTanSY_Altera
Richard Tan
RichardTanSY_Altera
Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Thank you and have a great day!
Richard Tan
