Hi all,
I'm moving into using DDR and DDR2 memory so I thought I would get myself up to speed by creating the simplest DDR2 simulation I could in qsys. Pity I couldn't get it to work.... simulation without a memory modelhttp://www.alteraforum.com/forum/attachment.php?attachmentid=9692&stc=1 You don't get much simpler than this. A DDR2 controller with its AMM slave exported. I ran a simulation of this successfully with the DDR2 controller attempting to initialise the memory. However, as there is no memory model, it doesn't initialise properly as expected. However, so far so good. simulation with a memory model
The next stage is to add the memory model. To do this, I used some of methods used in this tutorial: http://www.altera.com/education/demonstrations/qsys/simulation/simulation-online-demo.html In particular, I asked qsys to produce a test bench by adding BFM modules to the i/o. http://www.alteraforum.com/forum/attachment.php?attachmentid=9693&stc=1 This process produces a new qsys model with BFM modules added. This includes DDR2 memory model connected to the DDR2 controller. http://www.alteraforum.com/forum/attachment.php?attachmentid=9694&stc=1 Unfortunately, when I try and compile this, it doesn't like the memory model. --- Quote Start --- Error: sdram_my_partner: Altera DDR2 Memory Model for UniPHY does not support the QUARTUS_SYNTH fileset Error: sdram_my_partner: An error occurred while executing "error "An error occurred"" (procedure "_error" line 8) invoked from within "_error "[get_module_property DESCRIPTION] does not support the QUARTUS_SYNTH fileset"" (procedure "generate_synth" line 2) invoked from within "generate_synth alt_mem_if_ddr2_mem_model_top_mem_if_dm_pins_en" --- Quote End --- Now the DDR2 controller uses ALTMEMPHY as I'm on cyclone III and UniPHY isn't an option. However, the memory model is for UniPHY. This might be the cause of the issue. Any other ideas? I'm targeting the Cyclone III as I had problems simulating with the Cyclone IV. I might try Cyclone V with the UniPHY as I think this is an option. I hit the same problem with Quartus 13.0 and 13.1.
Get some external memory model for simulation, connect it to your design directly in Verilog simulation files, not in QSYS. Doing that you should not care if it's UniPHY or ALTMEMPHY. Micron provides nice models. Do not add manually BFMs, they will be generated by QSYS by default for simulation.
Thanks linas, that hint was what I needed.
For those coming across this later, this is what I ended up doing. I downloaded the Micron DDR2 model from here: http://www.micron.com/-/media/documents/products/sim%20model/dram/dram/3944512mb_ddr2.zip I modified ddr2_parameters.vh to include `define sg37E `define x16 I then created a qsys system with just a DDR2 controller https://www.alteraforum.com/forum/attachment.php?attachmentid=9706 (burst length was increased to 8) https://www.alteraforum.com/forum/attachment.php?attachmentid=9707 Generation included simulation but didn't include producing the test bench. https://www.alteraforum.com/forum/attachment.php?attachmentid=9708 Next was my test bench. (Yes I know there are better ways of driving the signals. This is just a quick hack)`timescale 1 ps / 1 ps
module microntest_TB ();
reg amms_address = 23'd0; // amms.address
reg amms_write = 1'd0; // .write
reg amms_read = 1'd0; // .read
reg amms_beginbursttransfer = 1'd0; // .beginbursttransfer
wire amms_waitrequest_n; // .waitrequest_n
wire amms_readdata; // .readdata
wire amms_readdatavalid; // .readdatavalid
reg amms_writedata = 64'd0; // .writedata
reg amms_byteenable = 8'd0; // .byteenable
reg amms_burstcount = 3'd0; // .burstcount
wire ext_local_refresh_ack; // ext.local_refresh_ack
wire ext_local_init_done; // .local_init_done
wire ext_reset_phy_clk_n; // .reset_phy_clk_n
wire mem_mem_odt; // mem.mem_odt
wire mem_mem_clk; // .mem_clk
wire mem_mem_clk_n; // .mem_clk_n
wire mem_mem_cs_n; // .mem_cs_n
wire mem_mem_cke; // .mem_cke
wire mem_mem_addr; // .mem_addr
wire mem_mem_ba; // .mem_ba
wire mem_mem_ras_n; // .mem_ras_n
wire mem_mem_cas_n; // .mem_cas_n
wire mem_mem_we_n; // .mem_we_n
wire mem_mem_dq; // .mem_dq
wire mem_mem_dqs; // .mem_dqs
wire mem_mem_dqs_n; // .mem_dqs
wire mem_mem_rdqs_n; // .mem_dqs
wire mem_mem_dm; // .mem_dm
reg clk_clk = 1'd1; // clk.clk
reg sreset_reset_n = 1'd1; // sreset.reset_n
reg greset_reset_n = 1'd1; // greset.reset_n
wire sysclk_clk; // sysclk.clk
always begin
# 10000
clk_clk <= !clk_clk;
end
always @ (posedge ext_local_init_done) begin
# 990000
amms_write = 1'd1;
amms_writedata = 64'h1234_5678_1122_3344;
amms_address = 8'h2;
amms_byteenable = 8'b11111111;
amms_beginbursttransfer = 1'b1;
amms_burstcount = 3'd1;
# 13333
amms_write = 1'd1;
amms_writedata = 64'hAABB_CCDD_AAAA_BBBB;
amms_address = 8'h13;
# 13333
amms_write = 1'd1;
amms_writedata = 64'h1111_2222_3333_4444;
amms_address = 8'h24;
# 13333
amms_beginbursttransfer = 1'b0;
amms_write = 1'd0;
amms_writedata = 64'h0000_0000_0000_0000;
amms_address = 8'h0;
amms_byteenable = 8'b0000_0000;
# 400000
amms_read = 1'd1;
# 13333
amms_read = 1'd0;
# 400000
amms_read = 1'd1;
# 13333
amms_read = 1'd0;
end
microntest uut (
.amms_address (amms_address), // amms.address
.amms_write (amms_write), // .write
.amms_read (amms_read), // .read
.amms_beginbursttransfer (amms_beginbursttransfer), // .beginbursttransfer
.amms_waitrequest_n (amms_waitrequest_n), // .waitrequest_n
.amms_readdata (amms_readdata), // .readdata
.amms_readdatavalid (amms_readdatavalid), // .readdatavalid
.amms_writedata (amms_writedata), // .writedata
.amms_byteenable (amms_byteenable), // .byteenable
.amms_burstcount (amms_burstcount), // .burstcount
.ext_local_refresh_ack (ext_local_refresh_ack), // ext.local_refresh_ack
.ext_local_init_done (ext_local_init_done), // .local_init_done
.ext_reset_phy_clk_n (ext_reset_phy_clk_n), // .reset_phy_clk_n
.mem_mem_odt (mem_mem_odt), // mem.mem_odt
.mem_mem_clk (mem_mem_clk), // .mem_clk
.mem_mem_clk_n (mem_mem_clk_n), // .mem_clk_n
.mem_mem_cs_n (mem_mem_cs_n), // .mem_cs_n
.mem_mem_cke (mem_mem_cke), // .mem_cke
.mem_mem_addr (mem_mem_addr), // .mem_addr
.mem_mem_ba (mem_mem_ba), // .mem_ba
.mem_mem_ras_n (mem_mem_ras_n), // .mem_ras_n
.mem_mem_cas_n (mem_mem_cas_n), // .mem_cas_n
.mem_mem_we_n (mem_mem_we_n), // .mem_we_n
.mem_mem_dq (mem_mem_dq), // .mem_dq
.mem_mem_dqs (mem_mem_dqs), // .mem_dqs
.mem_mem_dm (mem_mem_dm), // .mem_dm
.clk_clk (clk_clk), // clk.clk
.sreset_reset_n (sreset_reset_n), // sreset.reset_n
.greset_reset_n (greset_reset_n), // greset.reset_n
.sysclk_clk (sysclk_clk) // sysclk.clk
ddr2 ddr_inst (
.ck (mem_mem_clk),
.ck_n (mem_mem_clk_n),
.cke (mem_mem_cke),
.cs_n (mem_mem_cs_n),
.ras_n (mem_mem_ras_n),
.cas_n (mem_mem_cas_n),
.we_n (mem_mem_we_n),
.dm_rdqs (mem_mem_dm),
.ba (mem_mem_ba),
.addr (mem_mem_addr),
.dq (mem_mem_dq),
.dqs (mem_mem_dqs),
.dqs_n (mem_mem_dqs_n),
.rdqs_n (mem_mem_rdqs_n),
.odt (mem_mem_odt)
endmodule
This code, instantiates the qsys module then connects it to the Micron memory model. Finally, I put a script together to run the simulation set TOP_LEVEL_NAME "microntest_TB"
set QSYS_SIMDIR "microntest/simulation"
source $QSYS_SIMDIR/mentor/msim_setup.tcl
dev_com
com
vlog ddr2.v
vlog microntest_TB.v
elab
add wave *
run 80 us
Hopefully that is of help to someone.
