17249 Discussions
Qsys-Problem with read latency of registered inputs in tri-state bridge
Hi
I switched from SOPC builer to Qsys (Quartus 11.0sp1) today.
On my custom board I have a CFI flash device (S29GL128P10FF010) connected to my SOPC system through a tristate bridge. A DSP device (ADSP-21371) is connected to the flash through a custom designed tri-state bridge master.
At startup, the DSP boots from the flash with a pre-defined access time of 250ns (slowest possible). My FPGA (Cyclone III) is running at 30MHz and uses 6 clock cycles (50ns read wait, 85ns setup, 25ns hold + 1clock cycle = 200ns) to fetch the data from the flash device.
This was only possible by setting the incomming signals to not registered in the SOPC tri-state bridge. As far as I understand, all signals are now registered with Qsys new tri-state bridge concept and there is no way to change this.
However, there have been three new parameters integrated in the signal timings of the generic tri-state controller. The automatic converter set them to:
- Maximum pending read transactions = 3
- Turnaround time = 2
- Read latency = 2
I don't know what these parameters exactly do, but now it takes 10 clock cycles (333ns) to receive data from the flash which is too slow for the DSP! :(
=> Why are there 4 additional clock cycles (I would expect 2)?
=> Is there a way to unregister the input signals - or to use the old SOPC tri-state bridge controller with Qsys?
=> Will changing the timing parameters help anything?
=> Is there a detailed description with timing diagrams on these new parameters available somewhere?
I'll be glad for any suggestions.
Best Regards
Simon
Hi Simon!
I have the same problem! How do you solve it?
Best Regards
