I've got a largeish QSYS system with HPS and VIP suite modules, some dual-port RAM, etc. I've got a JTAG-MM Master hooked up to the control ports of the VIP modules, and I've got the HPS LW_AXI hooked up to those same control ports and some of the dual-port RAM. When my QSYS system is built, I get 5 mm_interconnect modules, and 4 of them are some 300-600 ALMs and the 5th is nearly 4000 ALMs. I've got them all clocked with the same clock, but for some reason this interconnect needs to take up a large percentage of my chip which I can ill afford. Would it be better to use the full AXI bus, not the lightweight one?
Cheers, SimonLink Copied
Qsys generates logic for every interconnection, and if you connect dissimilar masters to the same slave, the logic at each connection point can explode.
Try inserting a pipeline bridge such that all your slaves have only the pipeline bridge as a master, and then connect your masters to the pipeline bridge. I believe this is detailed in an appnote describing how to optimize Qsys designs, but I can't find the reference at the moment.- Mark as New
Thanks Ted, that's exactly what was required. Saved 3k ALMs!
--- Quote Start --- I believe this is detailed in an appnote describing how to optimize Qsys designs, but I can't find the reference at the moment. --- Quote End --- Do you have this app note somewhere available?
Turns out it is in the Quartus Handbook, not an appnote - see the section "Creating Dedicated Master and Slave Connections to Minimize Interconnect Logic" in Chapter 8 Optimizing Qsys System Performance of https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-5v1.pdf
The entire chapter is worth a read if you're spending any time with Qsys.- Mark as New
Thanks I will have a deeper look into it.
