Quartus version 10 seems to crash a lot 1/3 of the time when it gets to fitting. I get a different error most of the time but here are some of the errors. Any help would be appreciated.
*** Fatal Error: Access Violation at 0X0000000006C9B168 Module: quartus_fit.exe Lock in use: 9 Stack Trace: 0xfb167: tdb_dump_sp_cut_for_pt + 0x18207 (TSM_TDB) 0xf386b: tdb_dump_sp_cut_for_pt + 0x1090b (TSM_TDB) 0xf6faa: tdb_dump_sp_cut_for_pt + 0x1404a (TSM_TDB) 0xf63a7: tdb_dump_sp_cut_for_pt + 0x13447 (TSM_TDB) 0x7757f: TDB_LIST_OF_TIME_OPTIONS::clear_elements + 0x5c1f (TSM_TDB) 0x5d80f: tdb_sta_set_p2p_time_assignment + 0x8df (TSM_TDB) 0x11cf3: TAN_LOCAL_UTILITY::read_assignments + 0xb3 (TSM_TAN) 0x15d69: TAN_LOCAL_UTILITY::initialize_for_tdc + 0x899 (TSM_TAN) 0x31a07: TDC_TAN_CLOCK_UTIL::get_tdc_clock_uncertainty + 0x3f7 (TSM_TDC) 0xda035: FITCC_TDC_UTILITY::setup_tdc_utility + 0x4b5 (FITTER_FITCC) 0xdc6a9: FITCC_TDC_UTILITY::FITCC_TDC_UTILITY + 0x1e9 (FITTER_FITCC) 0x36c45: FITCC_ENV::get_tdc_utility_or_create_if_necessary + 0x265 (FITTER_FITCC) 0x1a61d0: FSAC_AUTO_GLOBAL_OP::~FSAC_AUTO_GLOBAL_OP + 0x57e0 (FITTER_FSAC) 0x814f: fcuda_execute + 0x4e0f (fitter_fcuda) 0x419af: FITCC_EXPERT::fitter_preparation + 0x23f (FITTER_FITCC) 0x4355b: FITCC_EXPERT::invoke_fitter + 0x3fb (FITTER_FITCC) 0x352e: fcuda_execute + 0x1ee (fitter_fcuda) 0xb17d: fmain_start + 0x7cd (FITTER_FMAIN) 0xfd5b: qexe_get_tcl_sub_option + 0xefb (comp_qexe) 0x133f5: qexe_process_cmdline_arguments + 0x605 (comp_qexe) 0x13521: qexe_standard_main + 0xa1 (comp_qexe) 0x1a88: msg_exe_fini + 0xf8 (CCL_MSG) 0x1a2c: msg_exe_fini + 0x9c (CCL_MSG) 0xa2b0: operator new[] + 0x130 (ccl_mem) 0x35ff4: msg_exe_main + 0x74 (CCL_MSG) 0x1f56c: BaseThreadInitThunk + 0xc (kernel32) 0x33020: RtlUserThreadStart + 0x20 (ntdll) End-trace another error *** Fatal Error: Access Violation at 0X0000000006C9B165 Module: quartus_fit.exe Lock in use: 9 Stack Trace: 0xfb164: tdb_dump_sp_cut_for_pt + 0x18204 (TSM_TDB) 0xf386b: tdb_dump_sp_cut_for_pt + 0x1090b (TSM_TDB) 0xf6faa: tdb_dump_sp_cut_for_pt + 0x1404a (TSM_TDB) 0xf63a7: tdb_dump_sp_cut_for_pt + 0x13447 (TSM_TDB) 0x7757f: TDB_LIST_OF_TIME_OPTIONS::clear_elements + 0x5c1f (TSM_TDB) 0x5d80f: tdb_sta_set_p2p_time_assignment + 0x8df (TSM_TDB) 0x11cf3: TAN_LOCAL_UTILITY::read_assignments + 0xb3 (TSM_TAN) 0x15d69: TAN_LOCAL_UTILITY::initialize_for_tdc + 0x899 (TSM_TAN) 0x31a07: TDC_TAN_CLOCK_UTIL::get_tdc_clock_uncertainty + 0x3f7 (TSM_TDC) 0x31ca3: TDC_TAN_CLOCK_UTIL::get_tdc_clock_uncertainty + 0x693 (TSM_TDC) 0xd9fd4: FITCC_TDC_UTILITY::setup_tdc_utility + 0x454 (FITTER_FITCC) 0xdc6a9: FITCC_TDC_UTILITY::FITCC_TDC_UTILITY + 0x1e9 (FITTER_FITCC) 0x36d3b: FITCC_ENV::get_tdc_utility_or_create_if_necessary + 0x35b (FITTER_FITCC) 0x23fbe9: FSAC_RP_UTIL::is_core_ff + 0x2bc9 (FITTER_FSAC) 0x248aa0: FSAC_RP_UTIL::sweep_all_stale_removable_wire_and_inverter_luts + 0x10 (FITTER_FSAC) 0x234fee: FSAC_FF_REGISTER_PACKER_OP::~FSAC_FF_REGISTER_PACKER_OP + 0x740e (FITTER_FSAC) 0x2380fc: FSAC_FF_REGISTER_PACKER_OP::FSAC_FF_REGISTER_PACKER_OP + 0x1afc (FITTER_FSAC) 0x892a: fcuda_execute + 0x55ea (fitter_fcuda) 0x419af: FITCC_EXPERT::fitter_preparation + 0x23f (FITTER_FITCC) 0x4355b: FITCC_EXPERT::invoke_fitter + 0x3fb (FITTER_FITCC) 0x352e: fcuda_execute + 0x1ee (fitter_fcuda) 0xb17d: fmain_start + 0x7cd (FITTER_FMAIN) 0xfd5b: qexe_get_tcl_sub_option + 0xefb (comp_qexe) 0x133f5: qexe_process_cmdline_arguments + 0x605 (comp_qexe) 0x13521: qexe_standard_main + 0xa1 (comp_qexe) 0x1a88: msg_exe_fini + 0xf8 (CCL_MSG) 0x1a2c: msg_exe_fini + 0x9c (CCL_MSG) 0xa2b0: operator new[] + 0x130 (ccl_mem) 0x35ff4: msg_exe_main + 0x74 (CCL_MSG) 0x1f56c: BaseThreadInitThunk + 0xc (kernel32) 0x33020: RtlUserThreadStart + 0x20 (ntdll) End-traceLink Copied
Try raising a service request with altera.
As a workaround, you may also want to switch to TimeQuest and try.
DK
