17254 Discussions
Quartus 12 - Fatal Error: Stack Overflow (HDB_OPTION, mast_disabled_for_iwap)
We have encountered the following errors. I need some helps. Sincerely thanks.
*** Fatal Error: Stack Overflow
Module: quartus_map.exe
Lock in use: 9
Stack Trace:
0x65f15: HDB_OPTION::HDB_OPTION + 0x15 (DB_HDB
0xcc750: HDB_FILENAME_OPTION::value_is_ok + 0xd0 (DB_HDB
0x230af: HDB_INSTANCE_NAME::find_single_option + 0xbf (DB_HDB
0x6bfcd: HDB_OPTION::relative_resolution + 0x1d (DB_HDB
0x6c07b: HDB_OPTION::relative_resolution + 0xcb (DB_HDB
0xeeef: HDB_OPTION::get_option + 0x3f (DB_HDB
0xedd6: HDB_ENUM_OPTION::get_enum_option + 0x46 (DB_HDB
0x48ec: QCU_ACF_SETTING: operator= + 0x205c (comp_qcu)
0x7f08: MAST_ADDER_HELPER: operator= + 0x6ef8 (SYNTH_MAST)
0x1490f: mast_disabled_for_iwap + 0x919f (SYNTH_MAST)
0x14b6c: mast_disabled_for_iwap + 0x93fc (SYNTH_MAST)
End-trace
Quartus II 64-Bit Version 12.0 Build 178 05/31/2012 SJ Full Version
try deleting the db and incremental_db directories.
Failing that, you will need to raise a my support request.
I tried but I need Altera my support request. Thank you.
I had recently a similar crash with quartus_map.exe . The source of that problem was that the message suppression file (.srf) was not compatible with the previous version of Quartus. Deleting the file, fixed the problem. That was however Quartus 12.1, so it may be a different problem.
