Sometimes (after minor changes) during project compilation fitter crashes with an error:
Error:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_legality_pincount.c, Line: 1332
Internal Error
Stack Trace:
0x573ec0: vpr_qi_jump_to_exit + 0x70 (fitter_vpr20kmain)
0xf20b7: vpr_exit_at_line + 0x97 (fitter_vpr20kmain)
0xf2100: handle_assertion_failure_stripped + 0x30 (fitter_vpr20kmain)
0x930e9: cl_legality_pincount_block_list_legal_for_inputs_and_outputs + 0x239 (fitter_vpr20kmain)
0x69470: l_block_list_feasible_with_specified_inputs + 0x150 (fitter_vpr20kmain)
0x69ccb: l_block_list_feasible_with_default_inputs_vpr_engine + 0xcb (fitter_vpr20kmain)
0x6646f: cl_block_list_and_first_ale_position_feasible_with_default_inputs + 0x1cf (fitter_vpr20kmain)
0x4a33f: l_anneal_try_ale_swap + 0x23f (fitter_vpr20kmain)
0x4a00f: l_anneal_try_pair_swaps + 0x20f (fitter_vpr20kmain)
0x4820f: l_anneal_prl_try_pair_swaps + 0x9f (fitter_vpr20kmain)
0x19e825: l_smid_job_thread_fn + 0x75 (fitter_vpr20kmain)
0x5c49cd: l_thread_start_wrapper + 0x3d (fitter_vpr20kmain)
0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
0x2791: thr_thread_begin + 0xa1 (ccl_thr)
0x1570c: BaseThreadInitThunk + 0xc (kernel32)
0x5385c: RtlUserThreadStart + 0x1c (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 7
OS version: 6.1
Quartus Prime Information
Address bits: 64
Version: 18.1.0
Build: 625
Edition: Standard Edition
Device: Cyclone V 5CEFA9F23I7
Deletting db doesn't help. Different fitter settings also doesn't work.
Hi Eugene,
Please let me know if you are able to resolve this using below suggestion.
Update:
I am able to pin down the IE is triggered during heuristic accounting of input pins to a cluster. This heuristic counting is used to generate packing that give more flexibility for router to resolve local congestions for outlier designs, so it should be generally safe to disable this. I have tried the INI to disable this algorithm and the design is able to compile successfully.
Here is the encrypted INI (copy and paste this ini in your qsf) for 21.1 std (encrypted INI support is only avaliable for 20.1std or newer) then recompile.
ini_password = 0f56f88f5713676e261178731ef27f42b49cd891b355d81b400032576444751330035221150003342320131030052576
- « Previous
- 1
- 2
- Next »
Hi Eugene,
Let me know if there is any update on this workaround.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 5/5 survey.
Hello!
Thank you so much for the solution! We tested it with our project in different settings and some changes, and it always compiles well without any errors. So it works. We wil use it. Thanks!
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
- « Previous
- 1
- 2
- Next »
