16690 Discussions
Quartus 23.4 shows 0.0 BER but negative eye height values
Ranjith21
I am running BER test for 2 FPGAs. I am transmitting from Tx pin of first FPGA and receiving on Rx pin on second FPGA. Using Quartus 23.4 here.
Both are Agilex F-tile F-series FPGAs. There is a total trace length of 13 inches between the FPGAs and the speed is 28Gbps NRZ PRBS31.
I set up a autosweep to sweep through different tap values in order to tune the channel
I notice that the results show negative eye height for many iterations but the corresponding BER is zero (see attached pdf)
How can this be possible?
Negative eye height means that the eye is closed. In this case we should expect maximum BER
Please help me understand what is going on here
Ranjith
Ranjith21
Adding more details:
The insertion loss between the FPGAs is ~15db.
ZiYing_Intel
Hi Ranjith21,
May I know the OPN board number that you use?
zying
ZiYing_Intel
Hi Ranjith21,
Negative eye height value means that the measurement height is calculated by Eye Center-to-top (Middle) minus Eye Center-to-bottom(Middle). For the positive height value, the measurement height is calculated from eye center to the top of the eye.
zying
ZiYing_Intel
Hi Ranjith21,
BER issue always related to channel loss. Please do make sure the RX channel is receiving data before starting eye measurement.
zying
Ranjith21
Hello @ZiYing_Intel
This is the FPGA part number AGFB027R31C2E2V
I have ensured that the RX channel is receiving data before starting eye measurement
ZiYing_Intel
Hi Ranjith,
Could you try to adjust the main tap value?
zying
ZiYing_Intel
Hi Ranjith,
Please do let me know if there is any update on the BER value when you adjust the main tap value.
zying
Ranjith21
Hi @ZiYing_Intel
I am sweeping different values for main tap as shown in the attached PDF. Still negative eye height with zero BER exists, please refer .pdf attached
Ranjith
Ranjith21
@ZiYing_Intel
Here is another autosweep showing the same issue
Attached
Ranjith
ZiYing_Intel
Hi Ranjith,
Could you try to increase the amplitude? Because I assume that the receiver side still have the minimum height limit on there.
From the analog side, the transmitter usually larger a bit than the receiver. The receiver side will have the minimum height limit on there and if the height is smaller than the minimum requirement, the signal might occur a lot error (BER).
zying
ZiYing_Intel
Since no hear any feedback from you, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
zying
Ranjith21
@ZiYing_Intel
Please check my comments. I have updated my responses on 02-20-2024
Please scroll up
Ranjith
ZiYing_Intel
Hi Ranjith,
zying
