17255 Discussions
Quartus 8.1, ActiveHDL 8.1 and testbench files linking
I have two parts: a design of a device and an emulation of LXT972 Ethernet transceiver, united in one testbench. I made it in Active HDL. The _device_ design was synthesised, but when i tried to make its gate-level (or RTL) test via ActiveHDL from Quartus II EDA tools link there is a strrange bug: the top test file is well compiled but it cannot link the TransEmulator file.
The minimalistic examples are here: TopTest, clock emulator and Top Device:
--ClockEmulator.vhd library ieee; use ieee.std_logic_1164.all; library work; entity ClockEmulator is port ( clkOut: out std_logic ); end entity ClockEmulator; architecture ClockEmulatorArchi of ClockEmulator is signal clkSignal: std_logic := '0'; begin process begin wait for 20 ns; clkSignal <= not clkSignal; end process; end architecture ClockEmulatorArchi;
--TopDevice.vhd library ieee; use ieee.std_logic_1164.all; entity TopDevice is port ( inPort: in std_logic; outPort: out std_logic ); end TopDevice; architecture TopDEviceArchi of TopDevice is begin outPort <= not inPort; end;
--TopTest.vhd library ieee; use ieee.std_logic_1164.all; library work; use work.all; entity TopTest is end TopTest; architecture TopTestArchi of TopTest is component TopDevice is port ( inPort: in std_logic; outPort: out std_logic ); end component TopDevice; signal topDev_inPort: std_logic; signal topDev_outPort: std_logic; component ClockEmulator is port ( clkOut: out std_logic ); end component ClockEmulator; signal clkEm_clkOut: std_logic; begin topDev: TopDevice port map ( topDev_inPort, topDev_outPort ); clkEm: ClockEmulator port map ( clkEm_clkOut ); topDev_inPort <= clkEm_clkOut; end;
How can i cope with it?
