17267 Discussions
Quartus 9.0 Error during Fitter placement operations beginning
I am trying to route a project on Quartus 9.0
During the Fitter process, an new message window appears in Quartus with an error. Then, the process is canceled.
Here is the message:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_clustering_ddio_support.c, Line: 744 Internal Error Stack Trace: 0x2440AC : VPR_QI_FACADE::vpr_qi_main + 0x23C (fitter_vpr20kmain) 0x818D5 : VPR_QI_FACADE::operator= + 0x80885 (fitter_vpr20kmain) 0x1EEF9D : VPR_QI_FACADE::operator= + 0x1EDF4D (fitter_vpr20kmain) 0x1EE909 : VPR_QI_FACADE::operator= + 0x1ED8B9 (fitter_vpr20kmain) 0x12D92 : VPR_QI_FACADE::operator= + 0x11D42 (fitter_vpr20kmain) 0x3F261F : VPR_QI_FACADE::`vftable' + 0x20FFB (fitter_vpr20kmain) 0x3B9F : fitapi_cfg_get_value + 0x9F (fitter_FITAPI) 0x13B92D : CUT_EQN_UTIL::fill_in_eqn + 0x4F73D (db_cut) 0x126A45 : __NULL_IMPORT_DESCRIPTOR + 0x12615 (axerces-c_2_6) 0x10731 : RtlAllocateHeap + 0x15D (ntdll) 0x10731 : RtlAllocateHeap + 0x15D (ntdll) 0x11595 : wcsncpy + 0xB06 (ntdll) 0x106EA : RtlAllocateHeap + 0x116 (ntdll) 0x10731 : RtlAllocateHeap + 0x15D (ntdll) 0x10731 : RtlAllocateHeap + 0x15D (ntdll) 0x11595 : wcsncpy + 0xB06 (ntdll) 0x236C4 : __set_flsgetvalue + 0xE (MSVCR90) 0x4F1B0 : _vcwprintf_s + 0x3FB (MSVCR90) 0x92E3 : cfg_get_value + 0x53 (ccl_cfg_ini) 0x130E9 : NLSPC_WAVE_POINT_LIST::get_slope_in_s + 0xFE9 (tsm_nlspc) End-trace Quartus II Version 9.0 Build 132 02/25/2009 SJ Full Version
This error happens for the moment only for that project. My operating system is windows XP SPS2 32BIT on 1GB of memory. I am wondering if it is because I have not enough memory.
Has anyone already been in that case of error?
Thank you for answers.
--- Quote Start ---
--- Quote End ---
there are two Service Packs for Quartus 9.0 available. Did you upgrade your SW ?
Kind regards
GPK
