17253 Discussions
Quartus 9.1 SP1 POF file generation
Hi All,
Has any one tried creating a POF file for the following setting using Quartus 9.1 SP1.
Devices: EP2AGX125EF29C6ES
CFI flash size: 512 MB
Mode: Fast passive parallel.
I am able to generate a POF file using the COF shown below only with 9.0 SP2.
<?xml version="1.0" encoding="US-ASCII" standalone="yes"?> <cof> <eprom_name>CFI_512MB</eprom_name> <output_filename>test.pof</output_filename> <n_pages>2</n_pages> <width>1</width> <mode>6</mode> <sof_data> <start_address>00640000</start_address> <end_address>00C4A78F</end_address> <user_name>Page_1</user_name> <page_flags>2</page_flags> <bit0> <sof_filename>test.sof</sof_filename> </bit0> </sof_data> <sof_data> <start_address>00020000</start_address> <end_address>0062A78F</end_address> <user_name>Page_0</user_name> <page_flags>1</page_flags> <bit0> <sof_filename>test.sof</sof_filename> </bit0> </sof_data> <version>4</version> <options> <map_file>1</map_file> <option_start_address>18000</option_start_address> </options> </cof> The above COF code is from Altera arria II gx development kit. I tried the same with 9.1 and 9.1 SP1, but both versions could not generate a POF file. The error is "Size of files(s) in CFI_512MB exceeds memory capacity". Am I doing some thing wrong?
Kumaran
There is a good idea to download programing file into EPCS(or CFI) via JTAG in Quartus II. In QII, file->Convert Programming Files.., Convert sof into jjc, then it works.
I guess you mean JIC. Quartus can create JIC file only for EPCS devices and my design has CFI flash. Thanks for your help.
Kumaran
In QII, file->Convert Programming Files.., Convert sof into pof, then it works.
It works in 9.1 SP1. I had to change the end address in the COF file to 0x0062A795 for page 0 and 0x00C4A795 for page 1.
Thanks for your help and time.
Kumaran
