Quartus Block/Symbol
I've write some vhdl files for my component for example:
a1.vhd ... a5.vhd and b1.vhd ... b6.vhd
I've crated two schematic with their block/symbols a.qsch and b.qsch.
But I can't use these two schematics as two component in my top_level...
How can I use this approach. I mean instead of drawing all blocks in the top-level schematic, create some block/symbols schematic and use these as new component in my top level design?
is it possible?
Once your vhd file is ready you can convert it into a Block Symbol FIle with
File>Create/Update>Create symbol files for current file.
After the symbol generation you will find the symbol in your Project folder and you will be able to insert it in your top-level bdf file by double-clicking on the sheet and choosing the symbol that you have created before.
if I may ask
what board do you work?
--- Quote Start ---
--- Quote End ---
Thank but I already know these:
I've design a.bdf with this approach form a1.vhd......a5.vhd
and b.bdf with this approach form b1.vhd.......b6.vhd
and now I want to use a.bdf and b.bdf in my top-level.bdf schematic.
my problem is I've had a lot of vhd files I want to draw my top_level.bdf form two three sub_schematic.bdf ....
is it possible? or I have to draw all block individually in my top-level.bdf?
P.S.if there is not possible so it's a good offer for next version of quartus.
Yes it is possible. Also to your sub_schematics bdf files you can apply:
Quartus will create a symbol which will represent your sub_schematics.
You follow this procedure for each of your sub_schematics and then you create a new top_level.bdf in which you will recall the three new symbols which were derived from your sub_schematics.
Thank a lot OrchestraDirector
