17255 讨论
Quartus Compilation took 4 hrs
名誉分销商 II
1,729 次查看
Hi all,
I am compiling a sample AES program from the book Design Recipes for FPGAs by Peter Wilson.
However, it took four hours to compile the two files. Here's the message from Quartus II:
Info: Started Full Compilation at Mon Oct 26 16:11:22 2009 Malay Peninsula Standard Time
Info: Ended Full Compilation at Mon Oct 26 20:27:12 2009 Malay Peninsula Standard Time
The example given use a package approach with a suite of VHDL functions rather than the structural approach.
Can any one suggest a faster setting for compilation?
Cheers,
Dennis
0 项奖励
3 回复数
名誉分销商 II
640 次查看
you didn't say anything about your target FPGA and the pc you run Quartus. Does this pc have enough memory or is it swaping ? also you didn't mention how you have setup your project.
What Quartus Version do you have ?
Maybe the meneu Tools -> Advisors -> Compilation Time Advisors may help you
0 项奖励
名誉分销商 II
640 次查看
I am running Quartus 9.0 sp2 on a WinXP SP3 with Core 2 Dual Processor with 4GB Ram.
Will take a look at the Compilation Time Advisors and feedback later.
0 项奖励
名誉分销商 II
640 次查看
Open You Quartus Project
Menue Assignments -> Settings
Compilation Process Settings
choose Parallel compilation . Use all available processors
enable Use smart compilation
Fitter Settings
Set fitter effort to Auto Fit
your system should be fast enough a Cyclone II EP2C70 design with ~70% usage is compiled here on a E8500 cpu within 50 minutes.
Is your project stored localy or via network ?
0 项奖励
回复
