17049 Discussions
Quartus II 13 problem! bumping on this one
Hi guys can someone figure out why Quartus II gives me the following error messages without me assigning anything to the .qsf file:
Error message is below:
Error (125048): Error reading Quartus II Settings File C:/altera_trn/VHDL_uppgift_4e/VHDL_uppgift_4e.qsf, line 41
Info (125063): set_global_assignment -name EDA_TEST_BENCH_MODULE_NAME "VHDL_uppgift_4e_vhd_tst " -section_id "VHDL_uppgift_4e_vhd_tst "
Error (125022): Section identifier missing or not required
Info (125063): set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst -section_id eda_simulation"
Info (125063): set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst " -section_id eda_simulation
Info (125063): set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst -section_id eda_simulation"
Info (125063): set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst " -section_id eda_simulation
Error (125080): Can't open project -- Quartus II Settings File contains one or more errors
Error: Quartus II 64-Bit Hierarchy Elaboration was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 381 megabytes
Error: Processing ended: Thu Dec 12 12:47:21 2013
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:00
Thanks for any help offered:oops:
Without the qsf file it's a bit hard to determine, but I'm guessing line 41 looks like:
It looks like it doesn't like the -section_id's for these guys.
Try changing the lines to:
and see if it helps.
Pete
--- Quote Start ---
Pete
--- Quote End ---
Hi Anakha, tried your suggestion but still it did not work. Thanks for the help and time.
Hi Anakha, here is the qsf file, thanks for the help:
# Copyright (C) 1991-2013 Altera Corporation
# Your use of Altera Corporation's design tools, logic functions
# and other software and tools, and its AMPP partner logic
# functions, and any output files from any of the foregoing
# (including device programming or simulation files), and any
# associated documentation or information are expressly subject
# to the terms and conditions of the Altera Program License
# Subscription Agreement, Altera MegaCore Function License
# Agreement, or other applicable license agreement, including,
# without limitation, that your use is for the sole purpose of
# programming logic devices manufactured by Altera and sold by
# Altera or its authorized distributors. Please refer to the
# applicable agreement for further details.
# Quartus II 64-Bit
# Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition
# Date created = 10:48:14 December 13, 2013
# Notes:
# 1) The default values for assignments are stored in the file:
# VHDL_uppgift_4ny_assignment_defaults.qdf
# If this file doesn't exist, see file:
# assignment_defaults.qdf
# 2) Altera recommends that you do not modify this file. This
# file is updated automatically by the Quartus II software
# and any changes you make may be lost or overwritten.
set_global_assignment -name FAMILY "Cyclone IV E"
set_global_assignment -name DEVICE EP4CE115F29C7
set_global_assignment -name TOP_LEVEL_ENTITY VHDL_uppgift_4ny
set_global_assignment -name ORIGINAL_QUARTUS_VERSION "13.0 SP1"
set_global_assignment -name PROJECT_CREATION_TIME_DATE "10:48:13 DECEMBER 13, 2013"
set_global_assignment -name LAST_QUARTUS_VERSION "13.0 SP1"
set_global_assignment -name PROJECT_OUTPUT_DIRECTORY output_files
set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0
set_global_assignment -name MAX_CORE_JUNCTION_TEMP 85
set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 1
set_global_assignment -name NOMINAL_CORE_SUPPLY_VOLTAGE 1.2V
set_global_assignment -name EDA_SIMULATION_TOOL "ModelSim-Altera (VHDL)"
set_global_assignment -name EDA_OUTPUT_DATA_FORMAT VHDL -section_id eda_simulation
set_global_assignment -name VHDL_FILE VHDL_uppgift_4ny.vhd
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT_AND_ROUTING -section_id Top
set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top
set_global_assignment -name STRATIX_DEVICE_IO_STANDARD "2.5 V"
set_global_assignment -name EDA_TEST_BENCH_ENABLE_STATUS NOT_USED -section_id eda_simulation
set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4ny_vhd_tst " -section_id eda_simulation
set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4ny_vhd_tst " -section_id eda_simulation
set_global_assignment -name EDA_DESIGN_INSTANCE_NAME NA -section_id "VHDL_uppgift_4ny_vhd_tst "
set_global_assignment -name EDA_TEST_BENCH_RUN_SIM_FOR "1 ms" -section_id "VHDL_uppgift_4ny_vhd_tst "
set_global_assignment -name EDA_TEST_BENCH_MODULE_NAME "VHDL_uppgift_4ny_vhd_tst " -section_id "VHDL_uppgift_4ny_vhd_tst "
set_global_assignment -name EDA_TEST_BENCH_FILE simulation/modelsim/VHDL_uppgift_4ny.vht -section_id "VHDL_uppgift_4ny_vhd_tst "
set_global_assignment -name POWER_PRESET_COOLING_SOLUTION "23 MM HEAT SINK WITH 200 LFPM AIRFLOW"
set_global_assignment -name POWER_BOARD_THERMAL_MODEL "NONE (CONSERVATIVE)"
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
