17256 Discussions
Quartus II Assignments -> Pins
I am new in quartus and altera fpga's.
I have a Stratix III EP3SL150 and I'm runing quartus II 8.0 web edition and 11.1 web edition as well and in bouth of them I have the same problem.
Wen I load the example that came with the instalation "my first fpga program" to the board it runs ok.
When I folow the tutorial to create my self the program, the first problem is thet when I do Assignments -> device to pick the correct board the model exists bet it saying thar t it is not installed. I use one other board to continue the tutorial, one that the tutorial acepts and everything goes ok, I do processing -> start -> start analysis & elaboration and it is ok with no errors and no warnings. The problen apears when I do assignments -> pins it moves to the correct window has in tutorial but does not apear the I/O pins that I created in the schematic so I cant conect to the output pins of the fpga.
so the main questions are:
Is it possible to download the information for the stratix III EP3SL150 to quartus II?
Is it suposed to the free web edition to execute the "my first fpga program" tutorial?
The web edition of Quartus does not support Stratix devices. Are you running on a development board of some sort?
Yes, I have Stratix EP3SL150 development boart to use at university and I instaled the altera software that came with it and got the web edition license on altera web page. I can load program to the board and it runs ok but I canot create program´s to it.
And one other thing I do not find normal is that I tried to create the tutorial for an existing board on quartus just for practice. I used Cyclone III EP3C120C780C7 and stil does not apear the node name of the I/O pins I created on the schematic in order for me to define the conections to the pinouts of the fpga in the "Pin Planer" window.
First you will not be able to compile a design to work in the Stratix III family using the web edition of the Quartus II tools. You will need to get a full license for the Quartus II tool to compile a design for the Stratix.
On your second issue. Did you at least run "Analysis & Elaboration" before you tried to assign I/O pins? If not you need to do so Processing -> Start -> Start Analysis & Elaboration". This is to build the database so that Quartus knows what the hierarchy looks like for your design along with the I/O pins.
Hope that helps
/Boris
Yes I did thats the previous step of the tutorial.
Try to compile the design to completion and see if you see the pins then
Info: Elaborating entity "altpll" for hierarchy "pll:inst1|altpll:altpll_component"
Info: Elaborated megafunction instantiation "pll:inst1|altpll:altpll_component"
Info: Instantiated megafunction "pll:inst1|altpll:altpll_component" with the following parameter:
Info: Parameter "bandwidth_type" = "AUTO"
Info: Parameter "clk0_divide_by" = "10"
Info: Parameter "clk0_duty_cycle" = "50"
Info: Parameter "clk0_multiply_by" = "1"
Info: Parameter "clk0_phase_shift" = "0"
Info: Parameter "compensate_clock" = "CLK0"
Info: Parameter "inclk0_input_frequency" = "20000"
Info: Parameter "intended_device_family" = "Cyclone III"
Info: Parameter "lpm_hint" = "CBX_MODULE_PREFIX=pll"
Info: Parameter "lpm_type" = "altpll"
Info: Parameter "operation_mode" = "NORMAL"
Info: Parameter "pll_type" = "Fast"
Info: Parameter "port_activeclock" = "PORT_UNUSED"
Info: Parameter "port_areset" = "PORT_UNUSED"
Info: Parameter "port_clkbad0" = "PORT_UNUSED"
Info: Parameter "port_clkbad1" = "PORT_UNUSED"
Info: Parameter "port_clkloss" = "PORT_UNUSED"
Info: Parameter "port_clkswitch" = "PORT_UNUSED"
Info: Parameter "port_configupdate" = "PORT_UNUSED"
Info: Parameter "port_fbin" = "PORT_UNUSED"
Info: Parameter "port_inclk0" = "PORT_USED"
Info: Parameter "port_inclk1" = "PORT_UNUSED"
Info: Parameter "port_locked" = "PORT_UNUSED"
Info: Parameter "port_pfdena" = "PORT_UNUSED"
Info: Parameter "port_phasecounterselect" = "PORT_UNUSED"
Info: Parameter "port_phasedone" = "PORT_UNUSED"
Info: Parameter "port_phasestep" = "PORT_UNUSED"
Info: Parameter "port_phaseupdown" = "PORT_UNUSED"
Info: Parameter "port_pllena" = "PORT_UNUSED"
Info: Parameter "port_scanaclr" = "PORT_UNUSED"
Info: Parameter "port_scanclk" = "PORT_UNUSED"
Info: Parameter "port_scanclkena" = "PORT_UNUSED"
Info: Parameter "port_scandata" = "PORT_UNUSED"
Info: Parameter "port_scandataout" = "PORT_UNUSED"
Info: Parameter "port_scandone" = "PORT_UNUSED"
Info: Parameter "port_scanread" = "PORT_UNUSED"
Info: Parameter "port_scanwrite" = "PORT_UNUSED"
Info: Parameter "port_clk0" = "PORT_USED"
Info: Parameter "port_clk1" = "PORT_UNUSED"
Info: Parameter "port_clk2" = "PORT_UNUSED"
Info: Parameter "port_clk3" = "PORT_UNUSED"
Info: Parameter "port_clk4" = "PORT_UNUSED"
Info: Parameter "port_clk5" = "PORT_UNUSED"
Info: Parameter "port_clkena0" = "PORT_UNUSED"
Info: Parameter "port_clkena1" = "PORT_UNUSED"
Info: Parameter "port_clkena2" = "PORT_UNUSED"
Info: Parameter "port_clkena3" = "PORT_UNUSED"
Info: Parameter "port_clkena4" = "PORT_UNUSED"
Info: Parameter "port_clkena5" = "PORT_UNUSED"
Info: Parameter "port_extclk0" = "PORT_UNUSED"
Info: Parameter "port_extclk1" = "PORT_UNUSED"
Info: Parameter "port_extclk2" = "PORT_UNUSED"
Info: Parameter "port_extclk3" = "PORT_UNUSED"
Info: Parameter "width_clock" = "5"
Info: Found 1 design units, including 1 entities, in source file db/pll_altpll.v
Info: Found entity 1: pll_altpll
Info: Elaborating entity "pll_altpll" for hierarchy "pll:inst1|altpll:altpll_component|pll_altpll:auto_generated"
Info: Quartus II Analysis & Elaboration was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 191 megabytes
Info: Processing ended: Wed Feb 29 19:25:29 2012
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:02
Brilliant. I did has you told me. I did "start compilation" and then I did Assignments -> Pins and finally the node names and direction appeared correctly on the pin planer window.
Thank you very mush for your help.
Great good luck with your project.
