16636 Discussions
[Quartus II] Automatically Implement Timing Advisor Setting
Hi All,
Is there a feature or script where you can automatically implement recommended settings by Quartus timing advisor?
I wonder if this can be done. I would like to try different settings configuration automatically on top of DSE and need to have the recommended settings implemented automatically.
Hope someone could help.
Note that DSE's highe effort levels will run through a lot of the options mentioned in the timing advisor. Also, you can do a custom DSE exploration space, but I'v never done it before and it will probably take some work to build.
