erro
名誉コントリビューター II
2,004件の閲覧回数
can any one tell me what is this error
Error: Node instance "Arbiter_1_1" instantiates undefined entity "Arbiter"
0 件の賞賛
10 返答(返信)
名誉コントリビューター II
1,226件の閲覧回数
you havent supplied the Aribiter source code.
名誉コントリビューター II
1,226件の閲覧回数
arbiter is a component and is declared.....
名誉コントリビューター II
1,226件の閲覧回数
You may have decalred it as a component, but it cannot find the entity (ie. the source code for arbiter).
名誉コントリビューター II
1,226件の閲覧回数
Sir,
Here is the defination of component 'Arbiter'.
COMPONENT Arbiter
PORT(Req, North, West, Mask: IN std_logic;
South, East, Grant: OUT std_logic);
END COMPONENT;
The instant of above arbiter is called as follows.
Arbiter_1_1: Arbiter
PORT MAP (Req => arb_req(1), North => High, West => High, Mask => c_bar_P(7),
South => south_2_north(1)(1), East => east_2_west(1)(1) , Grant => arb_grant(1)(1));
and the error is
名誉コントリビューター II
1,226件の閲覧回数
Like I said, that is just the component.
You need the source code for the entity.
A component is just a black box until you have an entity to link it to. A component on its own is useless.
Do you not have an arbiter.vhd?
名誉コントリビューター II
1,226件の閲覧回数
TO_BE_DONE
名誉コントリビューター II
1,226件の閲覧回数
I have no idea how the arbiter is supposed to work.
So only you can create the arbiter.
Why are you using a component called arbiter if you dont have the source code for it?
名誉コントリビューター II
1,226件の閲覧回数
hello sir...
thank you very much... i have created a entity called arbiter and its working.. but i want to see the RTL output of it .....how to check this in QUARTUS-II
名誉コントリビューター II
1,226件の閲覧回数
Click on RTL VIEWER. It's inside netlist viewers
名誉コントリビューター II
1,226件の閲覧回数
Thank you very much sir.......
返信
