16680 Discussions
Quartus II I/O bank voltage settings
Running into a problem when allowing quartus to set I/O bank voltage. Particularlly 1.8V
The tool generates the following in the .qsf
set_instance_assignment -name IO_STANDARD "1.8 V" -to ramAddrPout[10]
however when compiling I get the following error:
Error: Error reading Quartus II Settings File location, line# ##
Info: set_instance_assignment -name "IO_STANDARD" 1.8 V -to "ramAddrPout[10]"
But stickler is when reading the documentation they refer to all voltage IO as "voltage_value-V"
When I manually edit the .qsf to the following everything compiles fine. Is there a bug in the quartus tool. I don't understand why the tool generated .qsf isn't working until I edit "1.8-V" or "1.8V"
set_instance_assignment -name IO_STANDARD "1.8-V" -to ramAddrPout[10]
or
set_instance_assignment -name IO_STANDARD "1.8V" -to ramAddrPout[10]
D
I tried a Cyclone III test case in Quartus II version 7.2 SP3. The .qsf had "1.8 V" with a space, but Quartus did not give an error. The problem might be specific to your device family, but I suspect it is a bug that has already been fixed if you are using an older Quartus version.
i'm using webpack, would that make a difference?
It might, but I doubt it. I expect that the Web Edition and Subscription Edition use the same code for features available in both.
If you are using QII 7.2 SP2 or SP3, I suggest that you file a service request. If you are using an older version, I suggest that you try the latest version.
yeah, i'm using QII 7.2 SP3 webpack, will submit a service request.
D
