17252 Discussions
i create ram in maxII but it is error
I use max+plus II 10.2. i write the code but, the compiler says there is error.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY ram IS
GENERIC ( bits: INTEGER := 8; --# of bits per word
words: INTEGER := 16); --# of words in the memory
PORT ( wr_ena, clk: IN STD_LOGIC;
addr: IN INTEGER RANGE 0 TO 15;
data_in: IN STD_LOGIC_VECTOR (7 DOWNTO 0);
data_out: OUT STD_LOGIC_VECTOR (7 DOWNTO 0));
END ram;
ARCHITECTURE ram OF ram IS
TYPE vector_array IS ARRAY (0 TO 15) OF
SIGNAL memory: vector_array;
BEGIN
PROCESS (wr_ena,clk )
BEGIN
IF (wr_ena='1') THEN
IF (clk'EVENT AND clk='1') THEN
memory(addr) <= data_in;
END IF;
END IF;
END PROCESS;
--data_out <= data_in;
data_out <= memory(addr);
END ram;
LIBRARY ieee;
ENTITY ram IS
END ram;
BEGIN
BEGIN
END IF;
END IF;
END PROCESS;
END ram;
But the compiler says:
error line22: file unsupported feature error: condition statement in this region for signals not supported
Is anybody know How to solve this problem ? :)
max+plus II don't understand the IF clk'event inside another conditional block. Simply
reverse the posistion of the two statements:
IF (clk'EVENT AND clk='1') THEN IF (wr_ena='1') THEN
