17252 Discussions
Quartus II error: ddr2 ALTMEMPHY
Hi everybody,
I'm trying to use the ddr2 controller ALTMEMPHY on my Cyclone III ep3c120f780 devboard in QSYS.
I generate my sopc and then compile my quartus project with the FPGA top file declared in VHDL.
Then I have an error at the end of the synthetis (97%) :
Error (15873): Output port DATAOUT of DDIO_OUT primitive "MySOPC_cyIII_devboard:MyFPGA_cycloneIII_inst|MySOPC_cyIII_devboard_altmemddr:altmemddr|MySOPC_cyIII_devboard_altmemddr_controller_phy:MySOPC_cyIII_devboard_altmemddr_controller_phy_inst|MySOPC_cyIII_devboard_altmemddr_phy:MySOPC_cyIII_devboard_altmemddr_phy_inst|MySOPC_cyIII_devboard_altmemddr_phy_alt_mem_phy:MySOPC_cyIII_devboard_altmemddr_phy_alt_mem_phy_inst|MySOPC_cyIII_devboard_altmemddr_phy_alt_mem_phy_clk_reset:clk|altddio_bidir:DDR_CLK_OUT[0].ddr_clk_out_p|ddio_bidir_e4h:auto_generated|ddio_outa[0]" must drive input port I of an I/O OBUF primitive
It comes from the alt_mem_phy_clk_reset of the altmemddr_controller but this instance is generated automatically and I don't understand where is the error in my code.
I have also declared the FPGA top in verilog an then the error disapear when compiled.
Can somone help me because I want to program it in VHDL.
I have also attached my FPGA top files verilog and VHDL.
The SOPC is based on the design_standard of the ALTERA devboard.
I found the error. Some ports are declared in the qsys example as std_logic_vector(0 donwto 0) you need to define them as std_logic especially for mem_clk of the altmemddr.
--- Quote Start ---
--- Quote End ---
Thanks kakaboud!
Your answer fixed the problem for me - DDR2 in a QSYS system with vhdl as top level. I had to change the top level pin and the QSYS component declaration to std_logic instead of std_logic_vector(0 downto 0).
Cheers,
Greg
