17246 Discussions
Quartus II file generation
Is there a simple way to turn off all of the reports and extra files generated during compilation? I've already tried "Automatically generate a single report file after design processing" in the General/Processing option.
I don't really need a "*.done" file! :confused:
It lets you turn off the really big ones(.html and .eqn files), but I think those are finally off by default. I would recommend using the Assignments -> Settings -> Compilation Process -> Save Project Output Files in a Specified Directory, and set it to some subdirectory. It doesn't get rid of all the files, but it at least separates them from all the input files.
Yep, that works!
Thanks for the reply,
Brian
This is one of those things I'd love all designers to start doing. It really doesn't make a big difference, but just makes things cleaner.
