17266 Discussions
Quartus II hangs when trying to create new project
I have Quartus II installed under Ubuntu 13.10. It starts up fine, but when I click "finish" on the "Create New Project" wizard, it loads infinitely, stuck at 0%, then stops responding.
I have tried this in both the 32-bit and 64-bit versions, with the same results from both. Anyone know what might be causing the issue, or how to figure out what is causing the program to freeze?
fdms
I resolved this issue by choosing the project folder to be located where I have read and write permission.
