Quartus II will start on Ubuntu 14.10. And I've successfully programmed .sof file to Cyclone V. But, if idle for a few minutes, it crashes with the following report:
problem details Error: *** Fatal Error: Segment Violation at 0xffffffff00000000 Module: quartus Stack Trace: 0x214ed: addbyter + 0xd (curl.so.4) 0x22403: dprintf_formatf + 0xd33 (curl.so.4) 0x22a45: curl_mvsnprintf + 0x25 (curl.so.4) 0x216c2: curl_msnprintf + 0x82 (curl.so.4) 0x12646: Curl_failf + 0x126 (curl.so.4) 0x910f: Curl_resolv_timeout + 0x12f (curl.so.4) End-trace Executable: quartus Comment: None system information Platform: linux64 OS name: Ubuntu 14.10 OS version: 14 quartus ii information Address bits: 64 Version: 14.1.0 Build: 186 Edition: Web Edition Anyone having similar problems? Any solutions?Link Copied
- « Previous
- 1
- 2
- Next »
Pete,
Good, glad it got through. Yeah, it is definitely quirky -- For me, 15.0 has been a very pleasant experience so far... I was surprised to find that little quirk and so far it is the only type of crash I saw more than once. You are right -- I'm not getting any notifications. Lance- Mark as New
For me I had to rename the following files in the ./altera/15.0/quartus/linux64 directories to remove all the error message due to incompatible libraries.
crashreporter crashreporter.dep libccl_curl_drl.so libcrypto.so.1.0.0 libcurl.so.4 libssl.so.1.0.0 But it's been running well since then, although the powerplay power estimator seems to be off for Max 10 devices. (I have another topic open on that). Thanks for the help Pete
- « Previous
- 1
- 2
- Next »
