17255 Discussions
Quartus II mux for schematic entry?
Sorry for the newbie question:
I have Quartus II 4.2 Web edition.
I don't see a multiplexer symbol in the Quartus library, unless I open the Max II folder. Ok to use the Max II 74 series libraries?
JohnP
Hmm. No design files for MaxPlus logic cells.
Guess I have to make a mux from AND and OR gates?
Have you tried looking under megafunctions/gates/ ?
Clancy:
I placed "BUSMUX" into my desgn. I set the "width" parameter to 8, then double clicked on the mux icon, error message says:
Can't locate design file for entry "BUSMUX"
Use lpm_mux.
Make sure you have "Launch MegaWizard Plug-In" check box selected.
Press OK.
Select your HDL language (it will autogenerate a wrapper in the language you select).
Press Next and enter the mux parameters. Continue to Finish.
I hope this helps :)
Always use lpm_ library components if available.
