17268 Discussions
Quartus Lite 17.1 crash sitting fit stage on centos 7
jdarko
I get the following error during the fit stage when trying to generate a .sof:
Info (170194): Fitter routing operations ending: elapsed time is 00:00:07I
InternalError: Sub-system: CUT, File: /quartus/db/cut/cut_lcell_util.cpp, Line: 7104
Error in merging. Locked bit differs
Stack Trace:
0x6c809f: CUT_LCELL_UTIL::get_stratixv_assembler_lutmask(CDB_ATOM_NODE*, CDB_ATOM_NODE*, CDB_ATOM_NODE*, CDB_ATOM_NODE*, CDB_ATOM_NODE*, CDB_ATOM_NODE*) + 0xc8f (db_cut)
0x174f26: U2B_TRANSLATOR_AV_LAB_ALM::convert_alm_attributes(U2B_BCM_CONTENT*, CDB_ATOM_GENERIC*, U2B_ATOM_CONTENT*, U2B_CONFIG_SV_ALE*, U2B_CONFIG_SV_LAB*, int) + 0x1c6 (db_u2b)
0x173e5e: U2B_TRANSLATOR_AV_LAB::convert(U2B_ATOM_CONTENT*, U2B_CONFIG*) + 0x426 (db_u2b)
0x6a1f3: FSV_U2B_POSTFIT::check_u2b_configs_for_conflicts() + 0x663 (fitter_fsv)
0x6e494: FSV_U2B_POSTFIT::work() + 0xc4 (fitter_fsv)
0x6cf166: vpr_qi_u2b_postfit_work + 0xb6 (fitter_vpr20kmain)
0x82b02a: aa_flow_finalize + 0x7a (fitter_vpr20kmain)
0x835e32: aa_flow_fit + 0x82 (fitter_vpr20kmain)
0x6e2c64: VPR_QI_FACADE::vpr_qi_main() + 0x24 (fitter_vpr20kmain)
0x6853e: fitapi_run_vpr + 0x5e (fitter_fitapi)
0x47041: FSV_EXPERT_BASE::run_vpr() const + 0xc1 (fitter_fsv)
0x47582: FSV_EXPERT_BASE::place_and_route() const + 0xc2 (fitter_fsv)
0x49c54: FSV_EXPERT_BASE::invoke_fitter() const + 0xd34 (fitter_fsv)
0x4593b: fsv_execute + 0x41b (fitter_fsv)
0x2457e: fmain_start(CMP_FACADE*) + 0x4ae (fitter_fmain)
0x1f826: qfit_execute_fit(QCU_FRAMEWORK*, QFIT_FRAMEWORK*) + 0x1d6 (comp_qfit_legacy_flow)
0x1bda2: QFIT_FRAMEWORK::execute() + 0x282 (comp_qfit_legacy_flow)
0x23568: qfit_legacy_flow_run_legacy_fitter_flow + 0x218 (comp_qfit_legacy_flow)
0x4d671: TclInvokeStringCommand + 0x81 (tcl8.6)
0x51ec7: TclNRRunCallbacks + 0x47 (tcl8.6)
0x536e7: TclEvalEx + 0x947 (tcl8.6)
0xfb366: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
0xfb47e: Tcl_EvalFile + 0x2e (tcl8.6)
0x11ebc: qexe_evaluate_tcl_script(std::string const&) + 0x382 (comp_qexe)
0x18dcf: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x597 (comp_qexe)
0x19d7b: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x57e (comp_qexe)
0x3e06a: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x1065 (comp_qcu)
0x1c586: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6b3 (comp_qexe)
0x3b75: qfit2_main(int, char const**) + 0xc5 (quartus_fit)
0x40720: msg_main_thread(void*) + 0x10 (ccl_msg)
0x602c: thr_final_wrapper + 0xc (ccl_thr)
0x407df: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg)
0xa559: mem_thread_wrapper(void* (*)(void*), void*) + 0x99 (ccl_mem)
0x8f92: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x63f2: thr_thread_wrapper + 0x15 (ccl_thr)
0x427e2: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xa3 (ccl_msg)
0x22555: __libc_start_main + 0xf5 (c.so.6)
End-trace
1:04.20
Can I please get some assistance with this
geon_bluquette
I replicated this problem with the attached project. Opening the project and trying to compile results in the same error.
SyafieqS
Hi Jerry,
Is possible if you could provide us your design file for me to replicate the issue? You can attach it via private message/email feature there.
jdarko
Hi @SyafieqS, my company works with @geon_bluquette and he was able to replicate the issue on his end. Can you please  try his attached project. His attached project should be exactly what I tried.
jdarko
@SyafieqS in the project that @geon_bluquette posted. I forgot there are some environment variables that I told him to set that I need to get rid of (I have a better way of doing it now) that causes some issues when you try to open that project.
I'll fix it and attach the project
jdarko
Updating this ticket. Intel stated that there are no workarounds or tricks for this crash bug.
