17254 Discussions
Quartus Prime- Internal Error: Sub-system: PGME, File: /quartus/pgm/pgme/pgme_engine.cpp, Line: 4555
ultra205
Hello~
Please advise on the following phenomenon~
Environment
    SW : Quartus Prime SC Lite Edition(22.1 std)
    FPGA : MAX10(10M08AE144C8G)
In the Progammer
    Add file : *.pof
    After clicking the Start button
Problem Details
Error:
count >= static_cast<DWORD>(device_chain->size())
Stack Trace:
0x55ee1: PGME_PROGRAMMER::get_device_chain_with_dummy_jtag_bit + 0x161 (pgm_pgme)
0x3fe8f: PGME_PROGRAMMER::engage + 0x288f (pgm_pgme)
0x8b715: PGMWQ_PROGRAMMING_THREAD::run + 0x25 (pgm_pgmwq)
0x2c760: QThread::start + 0x3e0 (Qt5Core)
0x126ac: BaseThreadInitThunk + 0x1c (KERNEL32)
0x5a9f7: RtlUserThreadStart + 0x27 (ntdll)
End-trace
Nurina
Thank you for using Intel Communities.
Can you provide your .qar file so I can replicate the error?
To generate this, go to Project>Archive Project
Nurina
ultra205
Hello~
I am tring to program on on-chip flash memory but it still fails.....
Please check the project in the link below and let me know what is wrong.
https://github.com/ultra205/lemonlite.git
ultra205
ultra205
Hello~
I attached Archive Project you mentioned
Programmer -> Add Fle -> output_files -> pwm_ctrl.pof
"Sorry The Quartus Prime software quit unexpectedly"  happend
ultra205
Nurina
I just noticed you are using MAX 10 on Quartus 22.1std. I'm not sure how you're able to create the project on this version, MAX 10 is not supported in 22.1std/Lite and onwards.
Try using 21.1std/lite as this is the latest Quartus version that supports MAX 10: https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/devices-support.html#intel%C2%AEmax%C2%AEseries
Nurina
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ultra205
Hi~
Problem solved.
Thanks for your advice~
ultra205
Nurina
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Feel free to open a new thread or login to ‘ https://supporttickets.intel.com ’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If any answer from the community or Intel Support are helpful, feel free to rank your support experience by rating 4/5 survey. Please let me know of any inconvenience so that I may improve your future service experience.
Have a great day!
Nurina W.
