17251 Discussions
Quartus Standard Ampcrypt/Amplic encryption tools
mdidomenico3
I'm looking to use Quartus Standard with an encrypted custom IP core file, and I've seen mentions of Ampcrypt/Amplic tools in other posts which should enable this. How would I access these tools? Is there any publicly available information, or a way to download them?
KennyTan_Altera
You may find the answer in below:
- Files encrypted with IEEE 1735 cannot be read into a design for use with Quartus Prime Standard?
Answer: That is correct, IEEE 1735 only support in Quartus Pro.
- The device support table here: https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/devices-support.html#stratix%C2%AEseries is up to date?
Answer: That is correct, it is up to date
- Could you confirm that Quartus Prime Standard must be used to build binary files for Stratix IV/V devices, and that Quartus Prime Pro cannot be used?
Answer: I can confirm that.
- Could you confirm that there is no way to use IEEE 1735 encrypted files in a design targeting a Stratix IV/V device, since only Quartus Prime Pro supports IEEE 1735 encryption/decryption, and only Quartus Prime Standard supports building binaries for Stratix IV/V devices?
Answer: Yes, you cannot use it for StratixIV/V devices. This IEEE 1735 encrypted is only for Quartus Pro edition.
KennyTan_Altera
Hi Mike,
Can you check your email for this? As this will require some agreement to be sign.
mdidomenico3
Hi Kenny, I just a few follow up questions:
KennyTan_Altera
mdidomenico3
Would you be able to provide any status on this? I haven't heard anything back from the support team yet, thanks!
mdidomenico3
Thank you! I'll close out this thread as soon as I've receiving the ampcrypt/amplic tools.
KennyTan_Altera
Based on the last discussion, this have been resolved.
I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
