17252 Discussions
Quartus Web Edition will not launch on Windows 7
I’ve tried 14.1 and 14.0. Run as admin and not. Get a wait cursor for a moment then nothing. This is a VM I run on OS X 10.10 but I’ve been running EDA tools in it for years with no problems.
I assume its not a license issue since the instructions suggest it should at least give access to a tools item to set the license path.
Sorry if this is a common problem, I searched these forums and google’d and found nothing.
Thanks in advance,
hello
I think this version of Quartus II only works for 64bit OS.
did you check that?
Yes, its the 64-bit version of Win7 Home Pro. Thanks for the suggestion. Looking through the event viewer I found this error:
Faulting application name: qreg.exe, version: 0.0.0.0, time stamp: 0x547ffd98
Faulting module name: MSVCR120.dll, version: 12.0.21005.1, time stamp: 0x524f83ff
Exception code: 0xc000001d
Fault offset: 0x0000000000095c01
Faulting process id: 0xe68
Faulting application start time: 0x01d035d2dad395dc
Faulting application path: C:\altera\14.1\quartus\bin64\qreg.exe
Faulting module path: C:\altera\14.1\quartus\bin64\MSVCR120.dll
Report Id: 1977114c-a1c6-11e4-9d2e-005056eef8ae
Although this looks like the failure, I still have not been able to glean a solution.
Any ideas?
try raising an issue with altera mysupport
