- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Since Windows 10 will be released in the upcoming weeks I am wondering if some people have used a testversion of W10 with Quartus and Modelsim and what their experiences are. In other words do they both work on Windows 10?
Link kopiert
9 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Q15 works fine
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
ok, thanks.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you for sharing this info. I have not yet have Windows 10 now but soon will get it installed.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- Q15 works fine --- Quote End --- Quartus Prime 15.1 (and 14.1) also tested with Win 10 OS. However, if you also use Altera EDS-SOC 15.1/ ARM DS5, I experienced the following problem: building an officially released bare-metal sw example e.g. altera-socfpga-hardwarelib-fpga-cv-gnu the cygwin shell gives some fatal errors like:
arm-altera-eabi-objdump -d hwlib.axf > hwlib.axf.objdump
8 sh 6492 c:\altera\15.1\embedded\host_tools\cygwin\bin\sh.exe: *** fatal error in forked process - fork: can't reserve memory for parent stack 0x600000 - 0x800000, (child has 0x400000 - 0x600000), win32 error 487
243 sh 6492 cygwin_exception::open_stackdumpfile: dumping stack trace to sh.exe.stackdump
8 sh 4080 fork: child -1 - forked process 6492 died unexpectedly, retry 0, exit code 0x100, errno 11
/usr/bin/sh: fork: retry: no child processes
etc.
This error above is also with ARM DS5 14.1. Any help to solve this problem is greatly appreciated. Thanks: Zsolt
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
https://www.altera.com/support/support-resources/download/os-support.html
again,, this had been highlight a couple of times,,, windows 10 is not in the list until today. why don't just use those that had been tested?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- [url]why don't just use those that had been tested? --- Quote End --- Not everyone has the luxury of having multiple OS'. Where I come from you have to really look for non-10 systems.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You could always install a supported version of linux... that is free.
You could even run it inside a virtual machine on your windows machine.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- You could always install a supported version of linux... that is free. You could even run it inside a virtual machine on your windows machine. --- Quote End --- Tricky - What, if any, performance penalty would you expect running Quartus in a linux VM on a Windows machine vs. native linux on the same machine? Thanks, Bob
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- Tricky - What, if any, performance penalty would you expect running Quartus in a linux VM on a Windows machine vs. native linux on the same machine? Thanks, Bob --- Quote End --- No Idea - you'd have to ask Altera about that. But Ive run Quartus in a Linux VM on a Linux server - works just fine.
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
