17267 Discussions
Quartus and Windows 10
Since Windows 10 will be released in the upcoming weeks I am wondering if some people have used a testversion of W10 with Quartus and Modelsim and what their experiences are. In other words do they both work on Windows 10?
Q15 works fine
ok, thanks.
Thank you for sharing this info. I have not yet have Windows 10 now but soon will get it installed.
--- Quote Start ---
Q15 works fine
--- Quote End ---
Quartus Prime 15.1 (and 14.1) also tested with Win 10 OS.
However, if you also use Altera EDS-SOC 15.1/ ARM DS5, I experienced the following problem:
building an officially released bare-metal sw example e.g. altera-socfpga-hardwarelib-fpga-cv-gnu the cygwin shell gives some fatal errors like:
arm-altera-eabi-objdump -d hwlib.axf > hwlib.axf.objdump 8 sh 6492 c:\altera\15.1\embedded\host_tools\cygwin\bin\sh.exe: *** fatal error in forked process - fork: can't reserve memory for parent stack 0x600000 - 0x800000, (child has 0x400000 - 0x600000), win32 error 487 243 sh 6492 cygwin_exception::open_stackdumpfile: dumping stack trace to sh.exe.stackdump 8 sh 4080 fork: child -1 - forked process 6492 died unexpectedly, retry 0, exit code 0x100, errno 11 /usr/bin/sh: fork: retry: no child processes
etc.
This error above is also with ARM DS5 14.1.
Any help to solve this problem is greatly appreciated.
Zsolt
https://www.altera.com/support/support-resources/download/os-support.html
again,, this had been highlight a couple of times,,, windows 10 is not in the list until today. why don't just use those that had been tested?
--- Quote Start ---
[url]why don't just use those that had been tested?
--- Quote End ---
Not everyone has the luxury of having multiple OS'. Where I come from you have to really look for non-10 systems.
You could always install a supported version of linux... that is free.
You could even run it inside a virtual machine on your windows machine.
--- Quote Start ---
--- Quote End ---
Tricky -
What, if any, performance penalty would you expect running Quartus in a linux VM on a Windows machine vs. native linux on the same machine?
Bob
--- Quote Start ---
Tricky -
Bob
--- Quote End ---
No Idea - you'd have to ask Altera about that.
But Ive run Quartus in a Linux VM on a Linux server - works just fine.
