17268 Discussions
Quartus and licensing a Nios II processor
Quartus II 10.1 Web Edition on a Windows 7 64 bit Home Premium PC.
Run as administrator.
1. A Nios II processor was built following the method in nios ii hardware development tutorial (ver 3.3, dec 2009). The following SOPC Builder messages occurred:
# 2011.01.04 12:58:47 (*) Checking for plaintext license.
# 2011.01.04 12:58:48 (*) Couldn't query license setup in Quartus directory c:/altera/10.1/quartus
# 2011.01.04 12:58:48 (*) Defaulting to contents of LM_LICENSE_FILE environment variable
# 2011.01.04 12:58:48 (*) LM_LICENSE_FILE environment variable is empty
# 2011.01.04 12:58:48 (*) Plaintext license not found.
# 2011.01.04 12:58:48 (*) Checking for encrypted license (non-evaluation).
# 2011.01.04 12:58:48 (*) Encrypted license not found. Defaulting to OCP evaluation license (produces a time-limited SOF)
2. The processor was instantiated into a separate project schematic. The Quartus compile resulted in these warnings:
Warning: Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Warning: Unlicensed IP: "Nios II Processor(6AF7 00A2)"
Warning: Unlicensed encrypted design file: "C:/altera_hw/Research_Errors/Error_Test_6/cpu.v"
3. How can I resolve the license? The Web Edition is license free, but I'm not sure how far that extends.
There is evidence that a license may be required. A Tools --> License Setup in Quartus confirms my Web Edition, shows a Subscription Expiration of 2010.11, and has a Web License Update button. Clicking the button yields a failure to connect to the Altera website and advice to contact Customer Service. The "contact" procedure was unclear, appearing to be an e-mail to authorization@altera. No response yet.
A final note: this system has successfully run certain workshop projects associated with a BeMicro board and a Nios processor. However, these were canned demos. The warnings outlined above are my attempts to build a system starting at a more basic level. The BeMicro FPGA is successful for projects without a Nios processor.
So any thoughts on both the license and contacting Customer Service will be appreciated.
Only the Nios II/e core is free. To use Nios II/s or II/f in non evaluation mode, you need to purchase a license.
Thanks. The change to the /e was all that was needed.
