17255 Discussions
Quartus - assembler not generating sof file
By default Quartus assembler generates sof file, however, it's no more in our case. Any particular settings that is causing this ? The Quartus I am using is not an evaluation copy.
Sorry it's the first I use Quartus II and I don't know what licence I'm using because it was already installed on my computer,
so is there a way to know the licence I'm using ?
--- Quote Start ---
--- Quote End ---
You can see the IP-cores used in the project, if you expand the view in the window "Project Navigator / Hierarchy".
The Ip-cores should have a magic wand icon in front of them (as in attachment).
I have something like in the attach document.
I have problems with these following IP-cores
So the answer is - buy a full licence.
Ok thank you then
