17260 Discussions
Quartus compiles slow in Arch Linux
Recently I found out that Quartus II 15.0 compiles really slow in Arch Linux.
A nearly empty cyclone IV project took ~4 min to compile
While the same project took about 30sec to compile in Windows/Linux Mint
I know that Quartus may not intend to support other linux distro,
but I still wish to find out why and ways to fix it.
Any suggestion or ideas would be appreciated, thank you!
First do a "top" and "iotop" and while it's running and see what process is eating CPU time.
Quartus only has Red Hat Enterprise Linux as a supported platform, but I run it on Ubuntu all the time. I know it has had issues with "Compwiz" and other differences between REL and Ubuntu in the past..
Thank you for replying.
I did a compilation and see top, iotop and found out that all the CPUs are nearly idle, and it seems that there is no heavy disk IO either.
Here is a message that bothers me alot.
Info: Quartus II 64-Bit Fitter was successful. 0 errors, 83 warnings
Info: Peak virtual memory: 1461 megabytes
Info: Processing ended: Sun Sep 20 07:38:50 2015
Info: Elapsed time: 00:02:48
Info: Total CPU time (on all processors): 00:00:11
It seems like most of the time the program is doing nothing!
I guess http://www.alteraforum.com/forum/showthread.php?t=49104 has the same problem...
I had the same problem on Fedora. But when I turn off the Internet connection (i..e turn off Wifi) it runs fast. Stupid workaround, but it works: http://www.alteraforum.com/forum/showthread.php?t=49543 (http://www.alteraforum.com/forum/showthread.php?t=49543).
GooGooCluster
Thank you for the interesting solution...
Turn off the internet connection indeed make it run fast...
I suspect it is a software bug.
A practical workaround may be run quartus in unshare http://linux.die.net/man/1/unshare to block internet connection...
But if you are using an ip license, quartus_asm must be run with internet, or else no .sof file would be generated.
Hope quartus could fix the bug soon.
