17254 Discussions
Quartus does not support the module IO were defined as real or user defining ?
for example:
ENTITY interpolation_filter IS
PORT( clk : IN std_logic;
clk_enable : IN std_logic;
reset : IN std_logic;
filter_in : IN real; -- double
filter_out : OUT real -- double
END interpolation_filter;
Compiling eror:
Error (10414): VHDL Unsupported Feature error at interpolation_filter.vhd(39): cannot synthesize non-constant real objects or values
Error (10414): VHDL Unsupported Feature error at interpolation_filter.vhd(40): cannot synthesize non-constant real objects or values
The error log is self exaplanatory.
Real variables are not synthesized.
thanks for reply! it seems user defining type also will report error. please see the picture. this filter program was produced by the Matlab, so I can not make sure if the VHDL or Quartus does not support 'real' type in the module IO definition? br njjjl
