17261 Discussions
Quartus doesn't support Standard Verilog ?! (needs begin-end)
I get an error when trying to compile the following code:
genvar ii;
generate for (ii=1; ii<30; ii=ii+1)
assign x[ii] = y[ii] & ~(|(y[ii-1:0]));
endgenerate
the errors: near text "assign"; expecting "begin"
this block requires a name
the thing is, that it doesn't. this is a code that was simulated in modelsim and actually is already running on ASIC silicon,
so, am I missing something ? I have thousands of blocks like this in the design, and changing an operational code is not possible. so what can I do ?
Raanan
You are right according to Verilog 2005 Clause 12.4.1
--- Quote Start ---
Generate blocks in loop generate constructs can be named or unnamed, and they can consist of only one item, which need not be surrounded by begin/end keywords. Even if the begin/end keywords are absent, it is still a generate block, which, like all generate blocks, comprises a separate scope and a new level of hierarchy when it is instantiated.
--- Quote End ---
There's no restriction mentioned in the Quartus Verilog support notes. The only point I'm not completely sure about is, if Verilog 2001, the standard supported by Quartus, possibly differs in this respect, but I don't expect this. I also noticed, that Quartus requires a block name for the generate block, although it's optional according to the spec.
In so far, you're reporting an undocumented Quartus restriction and should contact Altera support.
--- Quote Start ---
You are right according to Verilog 2005 Clause 12.4.1...
--- Quote End ---
That's exactly the issue. This is an enhancement introduced by Verilog 2005. Not only it differs with Verilog 2001, it is not even supported by System Verilog 2005.
--- Quote Start ---
--- Quote End ---
I'm afraid you have no choice. You could make a script in your favorite text/parse language (Perl, awk or whatever) to avoid doing this manually. But yeah, I wouldn't be very happy in your place.
--- Quote Start ---
--- Quote End ---
Oh yes, I see. Thank you for clarifying.
