17256 Discussions
Quartus help - RTL Viewer does't update after changes in the code
On the very first time i open the RTL Viewer in any new project - it generates a schematic.
But if i change something in the Verilog code, compile, and open the RTL Viewer again, the RTL Viewer doesn't update accordingly.
The only way i can get it to update is clicking:
project > clean project
and then open the RTL Viewer again.
is there a nicer, more direct way to do it?
thx
What kind of changes are you making to the design? Are you saying you do a full recompile and RTL Viewer doesn't reflect those changes? What is your indication that things haven't changed?
If you make small changes to a design, you might not notice what synthesis has changed.
When you say you recompile after editing the code, are you doing a full recompile or just analysis and elaboration?
Also, what version of the software are you using? And are you using incremental compilation? Are there any strange warnings appearing during compilation?
Something is clearly stuck in the compilation database and either it's a problem with your installation or perhaps you've set up something with incremental compilation that is preventing the design from being recompiled.
What does the technology map viewer look like when you change the code?
I think i'm doing a full recompile: just pressing this purple "play" button:
https://www.alteraforum.com/forum/attachment.php?attachmentid=15492
at the end of the compilation i get this:
https://www.alteraforum.com/forum/attachment.php?attachmentid=15493
i get only those warnings:
https://www.alteraforum.com/forum/attachment.php?attachmentid=15494
this is my version:
https://www.alteraforum.com/forum/attachment.php?attachmentid=15495
later i also tried to start and compile only analysis and elaboration, doesn't work also..
what is incremental compilation? and if i'm using it by a mistake, it should detect my changes, no?
the technology map viewer (post-mapping), before and after the recompile:
https://www.alteraforum.com/forum/attachment.php?attachmentid=15496
Go to Assignments -> Design Partitions Window. Make sure the Netlist type is set to Source so it will always recompile back from source code.
it is already on source...
https://alteraforum.com/forum/attachment.php?attachmentid=15497&stc=1
should it be "Top" there? or something else..?
is there a way to only force generating a new netlist?
(though it is a "bandage" it will be 1 step forward)
I'm not sure what's going on then. Does this happen even if you create a brand new project? Can you try using a newer version of the software (13.1 is now almost 5 years old)?
